Widest tires on stock rims?
Old 04-16-2012, 04:43 PM
  #51
AMG E Power's Avatar
E55 amg
Originally Posted by AKnight55
Dont think those would fit in the front.. Pretty sure they would rub.
No I mean the stock tire size in the front with 285/30/18on the back
Old 04-17-2012, 12:52 AM
  #52
infantry's Avatar
07 E63. 07 STi limited #606/800
Granted I don't have stock wheels anymore.
I think my stock wheels were 18x8 Front and 18x9 Rears.
Now I'm sitting a bit wider 18x8.5 F and 18x10 Rear, and I'm using stock front tire size, and stuffing a 285 / 35 / 18 on the rears, and they hook much better than the 265's but there is still problems hooking up. It could also be due to the wheel setup being much much lighter.
Old 04-17-2012, 07:39 PM
  #53
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
You may have to get a bit of shorter tire in the front to match those rears.. I believe a 235/40/18 or 225/40/18 would match better than a 245/40/18 in the front.. Hope that helps
Old 03-16-2013, 02:49 AM
  #54
WPOZZZ's Avatar
W211 E55, 911 turbo, 911sc, RX330
Bumping an old thread, but I just changed out the 19 Weds on my car for stockers I got from a friend. Running 255/40 and 285/35 and the ride is much more compliant and it looks like I can go a little bigger, if the rims were .5" wider.
Old 04-23-2013, 04:29 PM
  #55
viren.89's Avatar
2004 E55 AMG
Yeah, I've seen people post here that they have seen a difference while running 255/40 in the front. Better handling
Old 04-23-2013, 06:05 PM
  #56
SilverStrk's Avatar
05 E55, 07 ML500
In the same boat.. Just ordered new Forgestar F14's 19" in either 8.5"F or 9" with rears an 10".. Am looking to run the widest tires possible thinking 255/265 Front and either 285/295 rears, not sure the 295 will go.. Any advice is apreciated...
Old 04-23-2013, 07:33 PM
  #57
viren.89's Avatar
2004 E55 AMG
Update us regarding running 265 in the front. I really think the highest one can go is 255/40 but I guess 265/35 could work too ?
Let us know what you end up doing.
Old 04-23-2013, 07:46 PM
  #58
AKnight55's Avatar
Pretty sure Jangy back in he day ran a 265 in the front. That may have been a 265/35/18 tire though. Find a set of rears Viren and run them in the front.
Old 04-23-2013, 09:24 PM
  #59
viren.89's Avatar
2004 E55 AMG
Lol I have 265 in the rears and I need new front 245/40 or 255/40 , so if I could just know I can run 265/35 in front I'd do it right away and get fat 285/35 in back lol
I was going to do a tire swap at home just to see if they rub but I do not have a torque wrench so after taking a tire off I won't be able to screw them back on to the right spec 130 lb/ft I believe.
K imma gonna try soon cuz tom car is going in for alignment and other stuff and let you guys know wish me luck. I hope traction doesn't go berserk with 265 in front and 245 in back lol
Old 04-24-2013, 12:09 AM
  #60
forcefed4door's Avatar
05 E55, 06 Audi S4
255-35 would be the correct size for fronts. 255-40 is too tall. it would work,but why?
Old 04-24-2013, 01:41 AM
  #61
WPOZZZ's Avatar
Wouldn't a 255/40 and 285/35 be better as they are closer in overall diameter at 26.1 and 26.0, than a 255/35 at 25.0?
Old 04-24-2013, 07:29 AM
  #62
05 E55, 06 Audi S4
by that point ide go 255-35 front and 285-30 rear. otherwise your going to have more than a half inch worth of taller tire.
Old 04-24-2013, 09:09 AM
  #63
viren.89's Avatar
2004 E55 AMG
So i'm guessing 255/35 in the fron and 265/35 in the back would be a bad combination
Anyone tried 265/35 in front and 285/35 in back ?
Old 04-24-2013, 09:45 AM
  #64
djrabbi's Avatar
CLS550 4Matic, C43, E350, ML350
i have 295s on my stock CLS wheels...i hear 305 even fits lol
Old 04-24-2013, 11:02 AM
  #65
viren.89's Avatar
2004 E55 AMG
CLS has more space to spare , I suppose eh
I just want to hear impressions from someone who put on 265/35 in the front.
Old 04-24-2013, 12:18 PM
  #66
SilverStrk's Avatar
05 E55, 07 ML500
I'll let you guys know what I decide to go with.. Shop told me I should go with 255/35front and 285/30 back.. Keep in mind these will 19" rims..
Old 04-24-2013, 02:08 PM
  #67
05 E55, 06 Audi S4
255-35 front and 265-35 rear would be a good combo.
Old 04-24-2013, 05:27 PM
  #68
viren.89's Avatar
2004 E55 AMG
Doesn't staggered arrangement dictate the difference of size from front to rear ? 255/35 front and 265/35 rear is less than 20 mm of difference
Anyone would like to go try 265/35 front ? and then 285/30 in the back well rear we know 285/30 would fit on stock rims
Old 04-24-2013, 07:41 PM
  #69
05 E55, 06 Audi S4
Well I personally would rather have the rear tires slightly higher . looks good that .
Old 04-24-2013, 09:08 PM
  #70
OZZYAMG's Avatar
03 W211 E55
Well I personally would. rather have the rear tires slightly higher . looks good that .
Hi
I would have to agree I would also prefer the rear tyres slightly higher than the front. I did read an article many years ago that AMG may not have made the best decision when the sidewall height of the front tyress and overall diameter of the front tyres were slightly higher than the rear on these cars. Interesting to hear what other people think about this.
Regards,
OZZYAMG
Old 04-24-2013, 10:23 PM
  #71
viren.89's Avatar
2004 E55 AMG
Originally Posted by OZZYAMG
Hi
Regards,
OZZYAMG
So what is considered Rear as a taller tire ?
255/35 in front and 265/35 in rear ?
Old 04-24-2013, 10:59 PM
  #72
OZZYAMG's Avatar
03 W211 E55
Hi
265/35/18 is definetly a taller tyre than a 255/35/18.
Regards,
OZZYAMG
Old 04-25-2013, 12:13 AM
  #73
viren.89's Avatar
2004 E55 AMG
Hi
Regards,
OZZYAMG
Okay, good to know. I'll put that in my search too but if you find that link where you read that or reference to the thread please post it up eh I want to see the pros and cons
Old 03-17-2014, 07:19 AM
  #74
OZZYAMG's Avatar
03 W211 E55
Hi
Has anybody had any problems with running 285/35/18 tyres on the rear of a standard E55?
I want to keep using the standard wheels and suspension but don't want the tyres to rub on the car.
Regards,
OZZYAMG
Old 03-19-2014, 11:51 PM
  #75
0-60inAMG's Avatar
2004 MB E55 AMG
I was running Michelin PS 2's from a SL55 on my stock E55 rims, front 255/40/18 and rear 285/35/18. All was great! No rub, better cornering and nice ride, looks great too with the wide rears.
I recently switched to 19in Vossen with 255/35/19 front and 285/30/19 rear but I am rubbing slightly due to the aggressive offset, I will have to roll my fenders on all 4 corners. All the best to your wider tires!!
Quick Reply: Widest tires on stock rims?
