Widest tires on stock rims?
I'm curious, what's the widest tires you can fit onto the stock rims? I have a 2006 E55.
Can you fit 275? 285?
Also, can you please post pics?
Thanks in advance folks!
Also, if going to a 285, wouldn't a 285/30 give close to the same profile height as a 265/35?
My rear tires are about shot and if I could squeeze a little more rubber in there with my next set, that would be nice.
If I don't like them, I can always sentence them to a smoky death by dyno mode.
With the known airmatic/strut failures I'm worried that if it fails and the car drops, if my tires are too wide it could cause some damage. God forbid it happen while driving. Either way would be bad if the tire was too wide. Additionally, I wouldn't want my speedometer to be off either since I'm usually pushing the tolerable amount over the limit as it is.
With these things in mind, if I'm running the stock 245/40 18's on the front, what size would I be able to add to the rear and have the maximum width for extra traction and still have an accurate speedometer?
Not sure the width of my wheels since they were on the car when I bought it but they are BBS as opposed to stock.
As always, thanks in advance.
Anyone see anything wrong with going with this considering my comments on the previous post?
Surely 1/2" in diameter wouldn't make a noticeable difference in the speedo but I wasn't a math major by any means. LOL Thanks again
You can play with wheel offsets, camber settings and specific tire manufacturers to get a combination that works...but it definitely takes effort. I didn't feel like taking that much time to figure it all out, so I went with a more conventional 275 width (Michelin PSS) and they work perfectly.
Diameters need to stay within 1 - 2% front to rear to avoid ESP issues. Visually, the 285s can also look too tall for the car....aesthetically speaking.
-G
tire height calculator.. you can put in several sizes and compare to your stock size. It also tells you what % your speedo will be off. Cool calc. Good luck.
stock rolling diameter is 25.7 front and 25.3 rear so find tires that are close to that and your speedo and traction will be fine.
I ran a 26.x in the rear and got tc issue because the car thought it was spinning out at higher speeds on the highway and it blinked the tc on with 5% throttle.
if you want to run a big fat tire in the back to get more traction,move the front tire up a level to get the car closer to what it likes.
I wanted to run 285s in the rear but didnt because of fear of having the same issues again.
this is a great site to play with tire (and wheel) sizing...
http://www.1010tires.com/TireSizeCalculator.asp
