Upgraded injectors and/or fuel rail needed with 168, headers, TB and intake system?
Old Dec 15, 2011 | 09:12 PM
Baronet1's Avatar
'05 E55, '12 C63
With the above mods, are upgraded injectors and/or fuel rail necessary?
I am thinking to buy HadiLaw's intake system.
I thought the fuel rail and injectors become necessary with too much boost (180+ pullies), but with a small pulley like a 168, it is unnecessary.
thoughts? feedback please.
Thank you
Old Dec 15, 2011 | 09:18 PM
Hammer Down's Avatar
2015 E63S, 2018 E63S
Thank you
Some will say that it's not needed but I say why take a chance with at one time a $30K engine? If you are going to mod and upgrade your TB you have to take the supercharger off anyway so why not add the TTM injectors & Fuel Rail. Don't take my word for it give Bruce @ TTM a call tomorrow and talk to him about it.
Old Dec 16, 2011 | 06:08 AM
320 dreamer's Avatar
2003 porsche 996 turbo
the fuel rail itself will help ensure all the cylinders get the same amount of fuel. the injectors ensure more fuel is getting there. im running a prototype rail on my s/c v6 and it dropped from a 11.8 afr to low 10 high 9 afr with the rail alone no injectors. that tells me the new rail flows a great deal of fuel
Old Dec 16, 2011 | 09:34 AM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
We usually dont look to fuel upgrades under 500 RWHP. Rough guess , you would be at 470-480 RWHP depending on what headers you run. I assume you will have a TUNE done with your list too?
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Dec 16, 2011 | 09:40 AM
Baronet1's Avatar
'05 E55, '12 C63
Yes, Kleemann headers with primaries deleted and their K2 tune.
That along with their 168 pulley would put the car at 470-480rwhp?
Old Dec 16, 2011 | 09:58 AM
Bramage's Avatar
F-250
I don't disagree with anyone here, but: Even at your level, your injectors will be running at a high duty cycle. Will they go static? I don't know, but I think the fuel rail is a great add, even early in the modding process.
Old Dec 16, 2011 | 01:23 PM
tbal's Avatar
Haters crazy
I've seen a lot of People with "modified" stock fuel rails. I'm assuming made into a return style? Any DIY?
Old Dec 16, 2011 | 06:28 PM
sneakyneon's Avatar
Bicycle
Boost is not the determining factor but HP. As stated above why chance it when modding an expensive engine.
Old Dec 16, 2011 | 08:57 PM
GT-ER's Avatar
2005 E55 AMG
On my car, with 500whp, I ran static from 5,500rpm up to redline. If I were to do it again, I would have gotten injectors even as a first mod because I can only imagine that after 450whp or so the oem injectors must already be dangerously close to static.
Old Dec 17, 2011 | 12:11 AM
KLR CLS's Avatar
CLS63 PP
FWIW I did injectors before I even did the boost increases. I Did
1. Cooling
2. Headers
3. Tune/Injectors
4. Pulley
5.Exhaust
6. TB and Airboxes
7. Dyno Tune
Have 2 years and several track days on it with nary a hickup.
Old Dec 17, 2011 | 12:47 AM
Bramage's Avatar
F-250
Get the TTM fuel rail. It is plug and play and many of the tuners have this dialed in. The rail is only half the equation. The TTM injectors are configured for a custom spray pattern that comes as close to direct injection as possible. Bruce put a lot of time into developing the kit and it works flawlessly
Old Dec 17, 2011 | 12:48 AM
motorkas's Avatar
a Rivera...via a Custom 24, Strat and Les Paul
for what it's worth:
with Kleemann headers, 168 pulley and two tunes dynoed on the same day, on the same dyno:
K2 =455hp/484tq
OE = 484hp/502tq
Old Dec 17, 2011 | 01:06 AM
turbo97se's Avatar
05 E55 AMG, E320 CDI, Turbo E46 M3,IS300 2JZGTE,VQ35 Turbo Maxima, Mercedes 300D
I agree with this .. though I did not do exhaust only because I want to keep things quiet. Everyone is right on here. Don't take chances on fueling, it's just not worth it.
1. Cooling
2. Headers
3. Tune/Injectors
4. Pulley
5.Exhaust
6. TB and Airboxes
7. Dyno Tune
Old Dec 19, 2011 | 09:57 PM
Baronet1's Avatar
'05 E55, '12 C63
K2 =455hp/484tq
OE = 484hp/502tq
Oh wow, I thought with the 168 and their headers, you would gain 100rwhp/100rwtq at the minimum, no?
What did you dyno stock? My car did 405/457 stock and I was hoping the hp would be close if not 500rwhp and the torque would be 600rwtq or close to that...am I wrong here?
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
