Kleemann header need delete primary cat ?
I think a great deal of the power gain comes from deleting the bottleneck primaries. I, for one, plan to delete the primaries and have Cory take care of the ECU tuning/"ready". However, I think leaving the cats in place might also help for reducing the low end torque loss...is this true? If so, I might opt to leave them in place, if this is possible.
Also, after doing research and talking to a few members, it seems if you don't use the downpipes provided by Kleemann with their headers, the alignment is off with the Kleemann headers and the primary cats.
Your best bet would be to call/email Cory and ask him. The guy is awesome and very helpful.
Someone correct me if I'm wrong here ...
http://www.amazon.com/Colorgard-Cera...4061551&sr=8-2
oh man, i can't see that paint surviving...
Beneficial, yes.
From what I've gathered after researching and reading, is that coating the headers properly and with a reputable company keeps the exhaust temps within the header instead of getting out into the engine bay. Thus reducing heat substantially in the engine bay. On top of that, coating helps get the hot gases flowing out and away through the exhaust more efficiently.
In the end, for the price you pay to get the headers coated and anything that helps with keeping things cool with these cars, I think it's a no brainer.
FWIW, here is the response I received from Cory regarding the primaries and deleting them. From this answer, I will definitely be deleting the primaries, I trust Cory's word:
backpressure:
Because this is a forced-induction engine, back pressure is your enemy, not your ally. When it comes to FI, you want to remove as much exhaust gas as quickly as possible, which means as free flowing as possible. If we were talking about a normally aspirated engine, I would have a different answer for you. Different header TYPES will effect the torque curve differently, but you will never see a LOSS of TQ by making the exhaust system as free flowing as possible.
It is not possible to use the factory primary cats with the KLEEMANN headers- there's simply not enough room- the factory catalyst only represent a restriction, and this is one of the reasons the KLEEMANN headers perform so well- we are removing all of the major restrictions from the system.
We have a dyno of an SL55 with the K2 package I did not long ago- I don't see any loss in low end TQ- quite the opposite, actually- this car made 566 lb/ft. at the WHEELS at a mere 3000 RPM so we actually gained low-end torque, as the stock car's peak torque wasn't available until about 3400-3500 RPM.
How about the water pump ? i search and they are about $80 right ???
