Pulley uninstall DIY (w/ pics)
Old Dec 19, 2011 | 11:26 AM
JoshM813's Avatar
2005 E55 AMG
Its very simple process...and this is the end result
Old Dec 19, 2011 | 11:36 AM
pearlpower's Avatar
E55 w/ goods, Z32 Project underway
Originally Posted by JoshM813
Its very simple process...and this is the end result:
http://imageshack.us/photo/my-images...218221933.jpg/
What happened? Send me a text if you prefer. Not torqued down enough?
Old Dec 19, 2011 | 11:42 AM
JoshM813's Avatar
2005 E55 AMG
Exactly what you think...bolt came loose pulley and keyway came off aswell...just regular driving.
Dont know exactly what caused it because it was on there good and had zero wobble...all I know is that they better repair it all correctly...
Old Dec 19, 2011 | 11:44 AM
grantwoodtx's Avatar
GLE 63S
Is that oil or coolant? Did the bolt back out? How long had it been on for? Did they use a fresh bolt? Torque it correctly?
Who did the install? I've had my ASP180 for nearly a year with 0 issues what so ever.
Old Dec 19, 2011 | 11:45 AM
pearlpower's Avatar
I was worried when we spoke on the phone with your indy. Did you watch them torque it down, I mean really torque it down, then torque angle it 90degrees? Seen a few here come off down the block. I hope the engine and pulley are OK, have you inspected?
Old Dec 19, 2011 | 11:54 AM
JoshM813's Avatar
2005 E55 AMG
Oil all over the place...
They said they torqued it to spec with the fresh bolt...i haven't throughly inspected it...it just doesnt make sense why it backed out
Old Dec 19, 2011 | 11:58 AM
JoshM813's Avatar
2005 E55 AMG
Also...only on for 2 days with normal driving
Old Dec 19, 2011 | 12:08 PM
pearlpower's Avatar
Yep, you said you were not going to go WOT until your tune. 100% of the time it is the install buddy. It is a stretch bolt, it must be torqued and then torque angled to stretch which locks it onto the crank. Check that crank stat, this could hurt. Sorry for this.
Old Dec 19, 2011 | 12:11 PM
JoshM813's Avatar
2005 E55 AMG
So your saying if they didnt do the 90 that would do it?
Old Dec 19, 2011 | 12:13 PM
pearlpower's Avatar
Yes, that is the big one and they need a good sized tree trunk (breaker bar) to do it. The bolt must stretch, otherwise it will come right out. The keyway is only for alignment, the torque is what locks the crank down.
https://mbworld.org/forums/w211-amg/...have-info.html
https://mbworld.org/forums/w211-amg/...-come-off.html
Old Dec 19, 2011 | 12:19 PM
JoshM813's Avatar
2005 E55 AMG
Well im gonna find out if they did or not...either way I have horrible car luck lol
Old Dec 19, 2011 | 01:12 PM
Jakpro1's Avatar
2003 E55 & 2014 GL550
Of course they will deny it....what shop would admit?
Bottom line is it wasn't torqued down properly...period bro.
I have literally had a half dozen pulleys on my car and my master tech with his buddies and huge breaker bars.....she never has come off.
I think sometimes techs are scared to go ape-sheet on those bolts in fear of breakage. It just won't.
My tech had a big buddy of his on one long pipe and him on the other. It scared the crap outta me but she was nice and snug and problem free.
****wanted to edit to add something. If they didn't have keyway aligned and DID crank to specs then same result will happen. They were cranking the pulley to specs against the actual keyway itself and once rocked off that keyway, she is loose and waiting to fly off like a 10lb frisbee.
Old Dec 19, 2011 | 01:26 PM
JoshM813's Avatar
2005 E55 AMG
Well ill see later what they say...all I know is that when I brought it in I told them 275lbs-ft + 90...
Also since I was just cruising I didnt notice immediately...think I need a new thermostat because it was over heating?
Old Dec 19, 2011 | 02:19 PM
GT-ER's Avatar
2005 E55 AMG
Wow...this sucks so bad. I remember when this happened to me it was such a disappointment because it made a simple install turn into a huge ordeal. Thankfully my DIY approached has worked like a charm and saved me hundreds if not thousands of dollars.
BTW- I LOL'd at the title...
Old Dec 19, 2011 | 02:27 PM
adianaty's Avatar
E55, CTS-V Wagon, Duc 1098R
I hope they didn't torque it to 275lbs ft plus 90 since that would have been your problem. The bolt will shear off at that kind of torque. It should have been closer to 150 lbs ft or 200NM.
https://mbworld.org/forums/w211-amg/209778-diy-pulley-install.html
Old Dec 19, 2011 | 02:35 PM
JoshM813's Avatar
2005 E55 AMG
According to Jerry@Eurocharged it is 275+90 for all eurocharged pulleys with the OEM bolt
Old Dec 19, 2011 | 02:37 PM
JoshM813's Avatar
2005 E55 AMG
Lol thanks I try to make the best of it.
Old Dec 19, 2011 | 02:59 PM
GT-ER's Avatar
2005 E55 AMG
Not true. Eurocharged states that the required torque is 275+90 on their pulleys. 150+90 would make it fall off in any case.
Old Dec 19, 2011 | 04:50 PM
GLE 63S
The bolt backed out= bad install.
Oh and torquing to that will NOT shear the crank bolt.
Old Dec 19, 2011 | 05:10 PM
AWOL's Avatar
e55
pullies are dangerous
Old Dec 19, 2011 | 05:20 PM
Helli217's Avatar
05 E55
Yeah seeing all of these posts makes me nervous. Make stay away from pullies. I live in upstate NY and there's no reputable benz peeps close by. I do all my other installs myself in the garage but this is frightening me. May have to stay in the stock pulley crew unless I wanna head down to the city and pay a grip for an install.
Old Dec 19, 2011 | 05:25 PM
JoshM813's Avatar
2005 E55 AMG
I'd go with the new S/C pulley...a lot safer than this...honestly it's alright aslong as you have a competent shop that actually listens
Old Dec 19, 2011 | 05:50 PM
adianaty's Avatar
Yeah forgot that this isn't a torque to yield but torque angle which makes it different.
Old Dec 19, 2011 | 06:08 PM
GT-ER's Avatar
2005 E55 AMG
Huh? It IS a Torque to Yield bolt.
Old Dec 19, 2011 | 06:19 PM
RedBullJnky's Avatar
you to Hate
Damn bro that sucks! I'm having my pully installed tomorrow. You are making me nervous.
