--spark plugs and spark plug wires-- need some suggestions
Hey guys am planing on getting a set of spark plugs and a set of wires and while i do that going to do the valve covers as well.. my question is which set of plugs would you guys use?
Spark Plugs:
http://www.ebay.com/itm/130598898472...ht_2040wt_1163
Bosch FR6MPP332 ebay $90 shipped
NGKR ILFR6A $?? not sure
Spark plug wires:
BOSCH Part # 09850 From RockAuto $170
Valve cover gaskets:
http://www.autohausaz.com/search/car...Cover%20Gasket
does anyone know that part number of the gaskets from parts.com
and also the part numbers for the two hoses one on the drivers side air box and the other one on the left side
thanks guys
Spark Plugs:
Spark plug wires:
thanks guys
1 Post
07' SL65, 04' E55, 03' Evo8, 08' GSXR, DSM's...
I used the NGK's in mine when i changed them and am using the OEM plug wires. I am stock. You may want to go a heat range colder if you have the normal bolt-ons. Good luck.
Aaron
Aaron
there is 4 different types of spark plugs here check em out..
http://www.autohausaz.com/search/pro...2@Spark%20Plug
and for Spark plug wire set
Beru Spark Plug Wire Set - 1131500019 $180
http://catalog.importrp.com/item.wws...rce=GOOGLEBASE
Karlyn/STI Spark Plug Wire Set - 1131500019A $175
I went with the bosch. I was told they are the OEM replacements to the stock NGKs. I really don't think it will make much of a difference if any, unless you are modded, then maybe a heat range colder.
I would recommend the Bosch wire set. The stock ones are Bosch. Just make sure to count them when you take them out of the box. Bosch admitted that some of their boxes were short of 1 lead. So you would only get 15 and not 16. It was only about $130 or so if I remember right for the whole set! Recommend long bent needle nose to remove the plug leads. The other brands are a bit iffy .. some you have to pull on the rubber boot to get them off. I don't like that. The bosch ones have a metal piece at the top to tug on
As for spark plugs NGKs all the way!!!
cheapest set i found is this
http://www.race-mart.com/NGK-NGK-ILFR6A.html
are the ones you bought from amazon these? ILFR6A Laser Iridium
I knew about the cheaper price at race-mart but found some bad reviews about em so decided to go with the always trusted amazon.
Holy **** yes!
W0133-1829574
I was looking for these forever and supposedly Bosch Part 09850 is it!
Great so, at checkout it disappeared from the cart and says not available.
W0133-1829574
