Car is totally dead. Need your help!
Noticed that the buttons around the hazard light are barely lit.. and stay that way.
Did some searching for possible causes.. battery, alternator.. but just not sure. Not even able to open the trunk to get the battery tested/charged.
Need your help... closest MB dealer is 30 miles away.
+1 I changed my battery 3 weeks ago cost $130 bought it in Autozone. I called AAA and they can test the battery voltage and appear to be the battery. You can open the trunk by the small key manually. Good luck !
I believe it's group size 49.
Is it unusual not to get any type of warning and for it to go completely dead like this? If so.. at least it happened at home..
It's common for batteries to die all at once like this. Probably it's been cranking a little slower lately, but too subtle a change to notice. Pop in a fresh battery and you'll likely notice it spins over much faster.
Aaron
Could swear that the owner's manual said to only jump the battery in the trunk.. If i'm wrong, my appoligies..
Anyhow... going to remove the battery tomorrow and see about getting it tested. Will go from there.
Bought the car in August, no idea how old the batteries are but will find out.. Hope it's that simple!
Even if you don't want to jumpstart or drive the car, you can use the jumper posts to power up the car. Then the key lock will work and the car can be shifted into neutral to roll it forward so the battery can be removed from the trunk.
Thanx for all your input!
