Old Jun 17, 2015, 07:15 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Transmission Guides
Print Wikipost
how to check transmission fluid level with OEM tranny dipstick?
Old Jan 2, 2012 | 01:35 AM
Shum_AMG's Avatar
nsx
hi, i have a oem tranny dipstick for 06 e55, but the dipstick did not go in all the way. it did not show anything on the dipstick when i pull it out. is it normal that the dipstick does not go in all the way?? plz help me out guys. thx.
Old Jan 2, 2012 | 01:39 AM
pearlpower's Avatar
E55 w/ goods, Z32 Project underway
Yes, it goes all of the way down to the pan. Not being silly, but are you placing it in the correct tube? Also, it should be round, sort of like a rope.
Old Jan 2, 2012 | 01:56 AM
Shum_AMG's Avatar
nsx
yes, i place it in the correct tube. its near by the firewall. it has some # on the dipstick. do you know whats the correct parts #?
Old Jan 3, 2012 | 01:22 PM
mikekuriger's Avatar
2010 C63
make sure you're not using the oil tube. The tranny tube is protected by a tamper proof cap.
Attached Thumbnails how to check transmission fluid level with OEM tranny dipstick?-tranny-cap.jpg
Old Jan 5, 2012 | 11:01 AM
gp500e's Avatar
2006 E55
The dipstick itself does NOT totally enter the tranny tube; however, it does go all the way town into the pan. These MB dipsticks are universal.
Old Jan 5, 2012 | 01:53 PM
Shum_AMG's Avatar
nsx
How far dose the dipstick go into the tube and how long did the dipstick outside the tube??
Old Jan 5, 2012 | 02:33 PM
gp500e's Avatar
2006 E55
I'm far from home (Miami Beach), but if I remember correctly it was a good few inches. LOL
You do have indicator marks at the end of that dipstick? Mine did. Can u post a pic?
Old Jan 5, 2012 | 03:19 PM
Shum_AMG's Avatar
nsx
Yes. It had indicator mark
Old Jan 5, 2012 | 04:45 PM
gp500e's Avatar
2006 E55
So if most of that dipstick went down that tranny tube you should be getting fluid on that dipstick. If not, your low. Instead if just adding fluid you may consider having a tranny service performed; draining/dropping the pan, changing the filter, gasket and drain bolt.
Old Jan 6, 2012 | 12:44 PM
Shum_AMG's Avatar
nsx
I just did a tranny svc. Replace filer, connector and oil gasket. Then I fill up 3.7qt. I wonder if the dipstick went down to the pan. Coz I did not get reading on the indicator mark. Maybe fluid low??
Old Jan 6, 2012 | 12:54 PM
pearlpower's Avatar
The dipstick can often get caught up in the middle. Play with it, rotate,etc while inserting to get past this point.
