Transmission Fluid Leaking , WHY ME
Old Jan 3, 2012 | 09:02 PM
Rafiki's Avatar
2016 AMG GTS
just the other day o left my car parked as usual, i get bcd from work, and see a puddle of oil, long story short i took it to my indy shop , happens that my transmission pan has to be replaced, because the mechanic suggested if i keep driving it it will mess up my transmission, already my trans had been lagging lately, staying too long in 3rd , $400 bucks ,
Old Jan 3, 2012 | 09:03 PM
Rafiki's Avatar
2016 AMG GTS
am just confused mbworld, has this happened to anybody
Old Jan 4, 2012 | 02:30 AM
pearlpower's Avatar
E55 w/ goods, Z32 Project underway
Do not understand why he needs to change the actual pan. The gasket could leak, however a gasket and filter cost under $20 new. Factor in 4 quarts of trans fluid-still at odds over $400.00. Also, common for the electrical connector to leak which could to fluid moving up into the TCU. A new connector is under $20.00 easy. Might as well do that while at it.
Old Jan 4, 2012 | 04:53 AM
Rafiki's Avatar
2016 AMG GTS
looking at the actual bill , i actually got charged 86 for oil change, and 300 for the electrical connector will , take a pic of the bill and post it when i get a chance to go back outside, i wanna know if i got swindled in paying that much,
Old Jan 4, 2012 | 05:36 AM
desired_speeds's Avatar
2007 SL55 AMG
The electrical connector is like a $20 part from the dealer and seriously takes a good 5 mins to replace once on the lift. If only the connector was replaced and fluid was topped off, you got ripped off. If he dropped the pan and did a whole service including filter and pan gasket and filled the trans back up with 4 quarts, then $400 ballpark isn't too bad. btw, the electrical connector is a common leak, so its not just your luck. It should always be replaced when you get a trans service with filter change.
and btw, where are you located?
Old Jan 4, 2012 | 07:48 AM
emoving's Avatar
3-five-five/ TUNDRA/ 07 997 cab
Sounds like your indy took you for a ride.
Old Jan 4, 2012 | 08:31 AM
Rafiki's Avatar
2016 AMG GTS
i think desired_speeds was right , it was the transmission pan gasket and the filter, so i guess that amount aint bad,
Old Jan 4, 2012 | 08:35 AM
Cylinder Head's Avatar
'19 E63S, ‘16 CLS63 RIP, '09 E63 Gone, '06 M5 Gone, '97 Supra TT Gone
$300 for a $20 part? You need a rape counsellor.
Old Jan 4, 2012 | 08:41 AM
Rafiki's Avatar
2016 AMG GTS
he dropped the pan and did the whole service , filter, pan gasket and filled it with 4 quarts of fluid back
Old Jan 4, 2012 | 08:52 AM
slownrusty's Avatar
'06 E55 K2
What about the other 5-6 qts of old oil still in the Torque Converter?
Old Jan 4, 2012 | 08:56 AM
Rafiki's Avatar
2016 AMG GTS
NOW THAT I DO NOT KNOW, GETTING TIRED OF THESE EVERYDAY THINGS, NOW THIS MORNING MY BRAKE LIGHT COME ON AGAIN, AFTER I JUST CHANGED ALL FOUR BRAKES , ROTORS AND SENSORS, WENT FROM NOT HAVING A SINGLE PROBLEM ON MY 07 LEXUS GS350 THAT I PAID OFF TO THIS , ARGHHH, WILL JUST PARK IT FOR THE WINTER, THE HEADACHE IS GETTING TOO MUCH,
Old Jan 4, 2012 | 08:58 AM
Rafiki's Avatar
2016 AMG GTS
DID A QUICK SEARCH , I AM HOPING ITS THE $16 STOP LIGHT SWITCH , IF IT IS THE SBC I HOPE MB IS GOING TO COVER IT, (111,760 MILES), ALTHOUGH, THE CAR DRIVES AND BRAKES JUST FINE
Old Jan 4, 2012 | 10:00 AM
Why would MB cover something with that many miles, and why are you shocked that a car with six-figure mileage is having issues?
Old Jan 4, 2012 | 10:06 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
invest in a STAR DAS system
Old Jan 4, 2012 | 10:55 AM
Speedriven1's Avatar
Speedriven
Swing by the shop and we'll scan it for you and let you know what you need. If it is the sbc brake unit, I believe MB cover it for 10 years.
Old Jan 4, 2012 | 12:30 PM
aghakauve's Avatar
GLC63s, W222 S63, W223 S580
I was thinking it was the connector.. On another note if these minor problems are pissing you off now your in for it big buddy
I would deffinatly do what shardul said "invest in a STAR DAS system"
Old Jan 4, 2012 | 12:36 PM
pearlpower's Avatar
True Dat.
Old Jan 7, 2012 | 12:11 AM
Rafiki's Avatar
2016 AMG GTS
LOOKS LIKE AM GOING TO PALATINE SATURDAY, WHAT TIME ARE YOU GUYS OPEN TILL , I GET OFF WORK AT 2 AND WORK IN SCHAMBURG, ..........PLUS AM SORRY PEOPLE THAT AM CRYIN LIKE A BABY, BUT U GOTTA UNDERSTAND I CAME FROM A 07 LEXUS GS350 WHICH FOR THREE YEARS ALL I HAD TO DO WAS OIL CHANGE, BRAKES AND BUY GAS, LOL, AND I BOUGHT IT AT 60KMILES AND DROVE IT TO 134K MILES , PROBLEM FREE
