Pano roof rattles/creeks
Do they all do it, or only some?
Does model year make a difference?
Mine is a 04.
The only caveat is that I have not had time to research the best lubes so I have been using Pedros ice wax which is a wax lube for chains. It works well but only lasts about a month. I need to do some homework on wax, silicone, or acrylic type rubber treatments to see what works best and lasts longer.
I'm not sure how I could post such a lengthy thing on here.
I think that there is a difference between some squeeking.... which can probably be made slightly better from lubrication... but creaking and rattling is just due to a crappy designed sunroof.
But, if today was any sign, I tried to email a wiring diagram with diag info and the website would not let me. I ended up having to take a picture of the computer screen with my phone and then emailing it.
I have used silicone spray in the past for lubing with good results. It will start creaking again after a few months, when it does just lube it again. Since I just did my front and rear brake pads and rotors I may try the same grease that is used between the rotor and the caliper next time on the pano. Just will use a very light coat and see how long that lasts.
Have you had this done and if so, where? I am in So Cal.
I also open all my windows and roof in the winter about 3-4 cycles (up down up down etc)every 2 weeks along with turning on the A/C. I also make sure the ABS pump is working my giving it a hard stop every so often.
NYC road are not the best and I have a quiet roof.
