has anyone found a piggy back that will theoretically work with the 55?
Sooo....any piggyback I should look at?
Although for the life of me I have no idea why you would want to use such a system.
As for why I would want such a thing? Cause I want control over my vehicles tune and no-one offers anything that will allow me to control it.
http://www.powermod.com.au/index-2.html
The ‘Pro Sequential’ ECU stands apart from most other piggy back computers because fuel mixture is modified by intercepting the actual fuel injector pulse signal, not by modifying Airflow meter or MAP sensor signals. This method enables engines with larger size injectors, even low resistance injectors, to be tuned with ease.
Retain your factory idle, cruise control, dashboard functions, fuel closed loop control, knock sensing, DSP, ESP and traction control.
Fuel can be modified +/-100% and ignition timing up to +/-50 degrees totally independent of each other at any engine speed or load.
On board 22psi boost MAP sensor ensures a correct tune even if the original engine sensors have been ‘saturated’ or reached their maximum reading. The PowerMod ensures a quick and easy tune with predictable and consistent results.
I think its much easier to invest our time and effort into flashing the factory ECU. Right now i'm researching a few companys that seem to have good options but are very expensive.
It's kinda pathetic that VW's/Audi's ( that use motronic ) have ecu tuner software available yet we don't.
Read This
http://web.dimsport.com/pdf/en/racestandard.pdf
or maybe Alientech
http://www.alientechtuningtools.com/...4352c9cf856831
Read This
or maybe Alientech
