Engine torquing too much. HELP...again.
I had my motor mounts replaced about a year ago or, if not less, and well...my motor began moving a lot when revving at idle(only revved at idle to listen to motor, not show off lol)
Does anyone have an under hood video while revving? Maybe I'm just paranoid, but to me it seems as if the mounts are bad...again, or weren't installed properly. There is a lot of movement.
Try to take a look around the motor mounts for any leaking oil. My understanding is these are filled with oil and leak when they go bad.
These mounts have an anchor bolt so, even if the top is torn, there will be a lot less movement than other mounts. Leaking mounts simply means that they have been broken for quite awhile and the top is completely torn and the anchor inside the mount is pulling the fluid out of the top. Because there is a boot on top of the mount, it is hard to see it broken until you do the D and R test. The amount of movement will show you whether it is broken or not.
Good luck.
PS Use only MB OEM mounts. I spoke to ProThane about building mounts and they wanted an initial order of 50 sets to develop them for me.
http://www.youtube.com/watch?v=tozRk2uzb9A
Good luck.
