To Those Running Eurocharged Longtubes
Old Feb 14, 2012 | 02:00 PM
nanayaw6's Avatar
2006 E55, 2006 saab 93 aero, 2010 glk 4m
Does anyone have a shot of their car while its on a lift? I have searched extensively and have run out of ideas for search strings. I am trying to see how they sit when compared to the stock setup ie trying to figure out if I can keep the plastic cover that goes under the oil pan with the setup I am going with. Do the collectors sit closer to the tranny, farther from the tranny or the same way the stock pipes between the primary and secondary cats sit. Thanks guys and gals.
Old Feb 14, 2012 | 02:04 PM
02S430's Avatar
W220 M113K
redbulljnky might have some ask him
Old Feb 14, 2012 | 02:47 PM
RedBullJnky's Avatar
you to Hate
Here's one. I'll take some better ones tomorrow.
Old Feb 14, 2012 | 03:07 PM
Benz-O-Rama's Avatar
Just call their shop?
Old Feb 14, 2012 | 10:26 PM
DVC's Avatar
DVC
Veteran: Army
'06 E55 AMG
That looks awesome RBJ! Who did your mid section? Are you happy with these LTs?
Old Feb 14, 2012 | 10:45 PM
you to Hate
Very happy! Rage-tek Has done all the work on my car. They have my car now. LSD and trunk tank going in. Getting ready for the private rental at PBIR on the 26th.
Old Feb 14, 2012 | 10:47 PM
DVC's Avatar
DVC
Veteran: Army
'06 E55 AMG
Awesome! I love your mod plans! I really like where your X pipe is as the bends are gentle. Will the underbelly pans go back on?
I wish someone would make a mid-section for the EC LTs
Old Feb 14, 2012 | 11:04 PM
you to Hate
Thanks! Only one pan stays off,because the Eurocharged LTs run a little low. Not a problem though. And the bends are exactly the way I wanted them. The flow is awesome.
Old Feb 15, 2012 | 08:28 AM
nanayaw6's Avatar
Thanks RedBullJnky
That's the exact area I was trying to see. Looks like all my fittings will work since I plan on retaining the stock secondary cat/h-pipe setup
Looking forward to some more shots. Would it be too much trouble to get one from the perspective of looking directly up at the tranny?
Old Feb 15, 2012 | 09:05 AM
grantwoodtx's Avatar
GLE 63S
As a suggestion to you guys getting long tubes fitted, have your shop add an extra bung before the cat/cats so you can run a wideband O2 sensor
Old Feb 15, 2012 | 09:26 AM
you to Hate
I'll get it later today when I go by the shop.
Old Feb 15, 2012 | 09:27 AM
kompressede's Avatar
Sold - 05' E55
RBJ - Those are just "sexy"
And it looks as though you have two bungs on each side?
Old Feb 15, 2012 | 09:30 AM
you to Hate
Thanks! And it does have two. Eurocharged FTW!
Old Feb 15, 2012 | 09:41 AM
SterlingE55's Avatar
2006 E55, 2012 Jeep SRT, 2008 G37s 6MT (The Mrs.), 2005 Explorer
Make sure it's BEFORE the cats. I had to have my shop added an extra one after and I had to have them redo it.
Old Feb 15, 2012 | 10:29 AM
DVC's Avatar
DVC
Veteran: Army
'06 E55 AMG
I wish Rage-tek could fab more mid sections just like that.
Old Feb 15, 2012 | 11:21 AM
nanayaw6's Avatar
Since the rear O2s get turned off why not remove them altogether so the wideband sensors take their place?
Old Feb 15, 2012 | 11:32 AM
I'm running high flow cats. If you're not going to run cats then no extra work needs to be done.
Old Feb 15, 2012 | 07:53 PM
nanayaw6's Avatar
I plan on only maintaining the stock secondary cats in the same configuration they currently have.
I am thinking the front O2 bungs on the collector will house the stock pre-cat sensors. The secondary bungs on the collector would house my wideband datalogger then thinking of extending the stock secondary sensors and installing them after the secondary cats so that way I could leave them turned on. If that's not feasible I was thinking of then eliminating those O2s altogether since they won't be doing anything for the car.
Old Feb 15, 2012 | 08:13 PM
I think you'll be much happier if you ditch the factory cats all together. Get a set of high flow cats (I got mine for ~$70) and don't extend the 02's. If your going to have cats in the system HFCs are the way to go. I'll post a link when I get home to where I got the cats.
Old Feb 15, 2012 | 09:36 PM
vipermike's Avatar
Viper SRT-10, CLS 55 AMG, 2012 Tacoma Off Road 4x4
Who makes the HFC? Are they ceramic or metallic?
Old Feb 15, 2012 | 09:48 PM
Metallic
Old Feb 16, 2012 | 05:23 AM
jmb614's Avatar
E55 AMG
Or two, one for each bank
