60hp recovered from dead IC pump to updated Bosch pump?
Subscribe
Feb 21, 2012 | 02:14 PM
Before:
371 hp, 411 lb
After service during which MB replaced pump with the most updated Bosch pump:
432hp, 454 lb
NB: a new OEM torque converter was swapped in between, but shouldn't have made a diff?
Reply 0
Feb 21, 2012 | 02:18 PM
the torque converter (if bad) would have not been putting down optimal power as well - but nice gains in replacement!!!
Reply 0
Interesting...
I'd always wanted to see a before / after dyno for the IC pump swap.
That's the cheapest 60hp you'll ever buy!.... What, about $2/HP?
-G
Reply 0
Feb 21, 2012 | 02:20 PM
Got to love that, enjoy your newly found powa
Reply 0
Feb 21, 2012 | 02:36 PM
Quote: Before:
371 hp, 411 lb
432hp, 454 lb
Can you also show a before and after AFR?
Reply 0
Feb 21, 2012 | 03:11 PM
Quote: Can you also show a before and after AFR?
Sorry, I only have the AFR from the first pull, as the wideband's connection to the dyno was kaput during the second session.
Reply 0
Feb 22, 2012 | 02:49 AM
torque converter
hey mate
y did u change the torque converter ??
could u feel it was bad ??
Reply 0
Feb 22, 2012 | 07:11 AM
I gained 35whp from a dead pump so yes, it matters...lol.
Reply 0
Explore
Feb 22, 2012 | 05:00 PM
I was getting jerky stumblin' when I go on boost at low revs/low gears. Apparently there was some TSB issued, and the stealership just robbed MBUSA of $2000 and installed a new torque converter under the extended warranty. They first changed the tranny oil/filter, but obviously that didn't do much. It's better now, but certainly not worth the tq converter swap.
(Note to those who may eventually read this when/if I sell the e55 wagon: 50% of commonly failing parts on my car has now been replaced under warranty. I think the only thing isn't new are the airmatic shocks)
Reply 0
Feb 22, 2012 | 05:33 PM
anyone know the best place to buy the bosch pump? i think my CM is done after about 2 years.
Reply 0
Subscribe
Currently Active Users (1)
