Oh my did I just crap myself...tranny went bye bye...
2005 E55 AMG
Except...that it didn't.
I did a WOT run in 1st gear and the car did a quick burn out. As soon as I got off the throttle it went into neutral and the car would not accelerate. I turned the car off and on again and everything was fine again.
Has this happened to anyone before?
2008 ML63 2009 SL63 2010 Alpha 7 GTR
Weird. But I've had my tranny go and it was like it just Went into neutral
05 White Pano E55, Cadillac CTS-V
Happened to me at the track twice after doing a burnout letting of gas quick and hitting brakes to stop before beams. Heard a thump and then car wouldn't go. Stomach sunk, did the same, shut car off and back on and all was good.
Yeah 2 things cause this (at least that I know of). The first being incorrect tire size (cel comes on, wheel speed error), the 2nd being low tranny fluid.
I used to have this problem when staging, bought taller drags and it went away.
Happened to me as well, except that I had put the car in neutral while decelerating off an exit ramp. Put the car back into drive while it was still rolling and it wouldnt accelerate. I stopped the car, shut it off. Started it back up and it was fine. Almost felt like a protection mechanism of some sort to protect the tranny.
Knew this sounded familiar...maybe you can follow up with the original poster.
Click on the link below for more info
https://mbworld.org/forums/sl-class-...e-limiter.html
2006 E55, 2006 saab 93 aero, 2010 glk 4m
My car has done this twice so far
Happened to me the other day, was in M mode and all of a sudden it was like the car was in neutral, I put it in neutral and back into drive and still nothing. I had to re start the car then it was fine. Hasn't happened again.
So speaking of, this past weekend I was out practicing launches, having some fun getting tires hot etc.....when same thing happens. Even check engine light came on. This was dyno mode. Cycle key all ok. Checked faults today had a code for slipping or impermissible trans ratio. I think this is just due to the heavy wheel spin, at least in my case ,sometimes only one wheel was going.
Me huh? I'm Pretty sure I am one of the few on this forum that have had this problem little alone have had to replace a transmission in an e55
When I was trying taller drag setup I got the car to go into a limp mode but I wasnt beating on it doing a burn out.
The car would not engage the blower and I scaned the ecu and wrong gear ratio code was throw so you might of freaked the car out and it just threw it self into N from spinning the rear tires so fast and the stupid T/C freaking out.
