URGENT: NHTSA Opens investigation into fuel leaks on the E55.
Old Mar 1, 2012 | 08:36 PM
BBBSS's Avatar
03 E55 AMG, 06 Harley Road King Custom 06 Ram 2500 Cummins, 97 Firebird Race Car, 88 Cutlass Supreme
Posting this new thread to bring attention to those of us who may not read the "Urgent notice. 03-06 E55's that were involved in the fuel sender recall are bombs" thread as its bumped over and over with the same issues we have read before.
Well, NHTSA Is actually actively investigating now and we need anyone that has had a problem and has not yet filed a complaint to do so ASAP. Reference NHTSA Action Number: PE12001. They are looking at this and if they give up its pretty much a done deal. We need to do anything we can to make this problem known more and more to NHTSA.
I'd emphasize the fuel leaks on the ground under the vehicle. They take this stuff very seriously.
A finding could lead to a recourse for those that have spent thousands out of pocket on these repairs.
Ok, I'm done being Toadster and making new threads about something in another thread now.
Find info towards the end of the thread here: https://mbworld.org/forums/w211-amg/...-bombs-15.html
COMPLAINTS CAN BE FILED HERE: https://www-odi.nhtsa.dot.gov/ivoq/
Old Mar 1, 2012 | 10:16 PM
GT-ER's Avatar
2005 E55 AMG
I filed mine a while back so I'm covered.
Old Mar 1, 2012 | 10:27 PM
400RWHP's Avatar
2006 CL600
Done and thanks for the heads up!
Regards
Old Mar 1, 2012 | 10:32 PM
SvtAmg's Avatar
2005 E55 amg
Thank you for taking the time to post that link. I have been super busy and been meaning to look that information up myself.
It's members like you that help keep this place still worthy.
Old Mar 1, 2012 | 10:36 PM
E55Bullet's Avatar
2008 ML63 2009 SL63 2010 Alpha 7 GTR
Thank you. Never had the issue (knock on wood) but I'm expecting it. So will MB fix it themselves for free eventually?
Old Mar 1, 2012 | 11:41 PM
black06c230's Avatar
mgLipGD
Same here I just try not t fill the car up more than 3/4 a tank. However, should I click the link and say I had the problem so that should it occur we aren't left out by not having that many complain?
Old Mar 2, 2012 | 12:15 AM
BBBSS's Avatar
No need to make false claoms. Hopfully NHTSA will force Mercedes arm tobdoba real fix for us and not this BS metal insert that does nothing.
Old Mar 2, 2012 | 10:09 AM
Toadster's Avatar
2005 E55 AMG
MODS - this should be a temporary sticky at least until the NHTSA closes the case - no extre blabber in here, just people that have posted for the issue
this is a big safety concern, and deserves visibility...
Old Mar 2, 2012 | 12:04 PM
moosejaw's Avatar
none
I agree with BBBSS. Do not make false claims. Being honest is the best way to get this resolved. One false move on our part can raise suspicions esp since your post is now documented and NHTSA does read automotive forums to gather as much information and facts as possible.
Ask a mod to delete it if you are not able to do so.
I just submitted my claims form acc to the link above in the first post
Claim # 10450058
Old Mar 2, 2012 | 01:40 PM
isellbenz's Avatar
2005 C230WZ, 2004 E55, 2004 Audi S4
Just had this done 2 days ago. $800+ bill. NOT FUN!
Old Mar 2, 2012 | 01:45 PM
moosejaw's Avatar
none
You should get reimbursed for this
I would go back to the dealer and let them know ASAP
Old Mar 2, 2012 | 03:00 PM
AMGPilot's Avatar
2004 E55
Complaint number 10450082 filed
Old Mar 2, 2012 | 05:13 PM
isellbenz's Avatar
What do I tell them??
Old Mar 2, 2012 | 05:59 PM
moosejaw's Avatar
none
Print out the link I made in the "bomb" thread and show it to them
Ask them will you get your money back?
Old Mar 2, 2012 | 07:05 PM
BBBSS's Avatar
I doubt you will receive anything back till after Mercedes has had a chance to respond to the complaint with their findings and solution to the issue. Hopefully no B.S. metal insert type answer again. Toyota got away with a tiny .01 cent metal washer for their sticky throttle problems. Manufacturers are notorious for half assed fixes when they can get away with it as costs to bring in thousands of cars can grow into the millions quickly. The fact that their first junk response to this problem has failed miserably maybe they will try a lil harder this time.
It's still an investigation that is ongoing and reimbursement will be based on what NHTSA feels is a proper repair for this plus how Mercedes treats people that have paid for these repairs in the past. Independent shops doing the work can lead to a grey area here.
New sending units would be great as I feel that is the only answer to this problem. Also the leaky sealing area of the gas tank itself needs to really be looked at as well. Seems there are two problems here. Nipples breaking off, and improper forming of the gas tanks at the threads/selaing surface of the drivers side sending unit when they were molded.
Old Mar 2, 2012 | 07:14 PM
TonyC's Avatar
e63 p30 estate
So don't file if you didn't find gas on the floor? I definitely saw gas stains on the tank after it was pulled out.
Old Mar 2, 2012 | 07:19 PM
BBBSS's Avatar
If you had fumes/a leak/signs of a leak I would make a report. Did you have repairs performed by a shop? If you did I'd keep receipts in a safe place pending the outcome of this.
I would note that you had fumes, learned of this common problem and found what you believed to be stains from a fuel leak on the top of the tank if that is indeed the case. The problem is very real and we do not need to make up any stories here. The evidence speaks for itself.
Old Mar 2, 2012 | 08:44 PM
MB_Forever's Avatar
E63 P30, CL500 Sport
It is important to note that this problem is not limited to E55s.... it seems to affect MANY W211 MODELS. I've seen E63s, E350s, E500, E550s, etc... encounter the same problem. Maybe this link should get posted in the non-AMG W211 section as well (if it hasn't already).
Old Mar 2, 2012 | 08:55 PM
BBBSS's Avatar
Just made this thread over in the W211 E Class section.
https://mbworld.org/forums/e-class-w...ml#post5083892
Old Mar 2, 2012 | 09:01 PM
moosejaw's Avatar
none
Did you have gas puddling up after you removed the seat and inspected the fuel sender?
Old Mar 3, 2012 | 12:15 AM
TonyC's Avatar
e63 p30 estate
There were gas stains around the fuel sender, and apparent dampness, but I didn't see puddling like others. Either way, the damned cabin REEKED.
Old Mar 3, 2012 | 12:34 AM
moosejaw's Avatar
none
Not good
Definitely a concern if you have family/kids
What would happened if you were driving and they were to pass out
Yes this recall covers fumes leaking into the interior that so file a claim!
Old Mar 3, 2012 | 01:26 AM
TonyC's Avatar
e63 p30 estate
Not good
FWW, both fuel senders + tank were replaced under MBUSA extended warranty. I'll file the NHTSA report ASAP.
Old Mar 3, 2012 | 02:19 AM
BBBSS's Avatar
Good to see you didn't get stuck with the bill. Even those that had the repairs paid for under warranty need to report the problem as it has been proved that the repairs do not hold up in a number of cases. Sooner or later you may be paying to replace that cracked sending unit out of pocket. Having the part revised or some sort of solution provided from Mercedes is what we need and they have not wanted to spend the time or money to fix this. Unfortunately (or fortunately?) this one is biting them thanks to the reports that everyone has made.
Old Mar 3, 2012 | 08:58 AM
gnma's Avatar
'12 Mustang 5.0, '89 Supra Turbo, C55,
Claim # 10450058
Just read your claim. Very clear,and concise. Hopefully they will force MB's hand to make good on this issue.
BTW, the RX-7 is pure Hotness!
You have already rated this thread Rating: Thread Rating: 12 votes, 5.00 average.
