Old Jun 15, 2015, 07:46 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Electrical Guides
Print Wikipost
Turning off Secondary O2 sensors
Old Mar 3, 2012 | 12:47 PM
raleigh29's Avatar
06 CLS55, 03 BMW M3
Earlier this week, I got my Kleeman headers and Pulley installed. I got my EC tune yesterday.
As we all know with installing Kleeman headers, you lose your secondary (Post primary cat) 02 sensors. I saw the leftovers of my exhaust system and my secondary 02 sensors are totally unplugged.
I got my tune from EC and still have codes P0140, 141, 160 and 161(all associated with secondary 02 sensors unplugged). After talking with Adam at EC and consulting with Jerry, he said they couldnt get rid of those codes to clear the check engine light remotely and that I would have to get them coded out in STAR DAS.
Anyone got any info on where in STAR to do this?
Old Mar 3, 2012 | 01:04 PM
Roverron's Avatar
ML63
you will have to have the rear O2 in th stream and then turned off.
they must be hooked up and in the exhaust stream.
Old Mar 3, 2012 | 02:10 PM
nanayaw6's Avatar
2006 E55, 2006 saab 93 aero, 2010 glk 4m
From my understanding as I just talked to Jerry about this yesterday, they aren't exactly turned off but the reading is manipulated to not trigger the CEL. Jerry mentioned just like reverron did that they have to be plugged into the car. You cannot disconnect them physically.
Old Mar 3, 2012 | 06:06 PM
novae500's Avatar
W211
Not sure why the rears weren't plugged in...they should be. Might want to try my trick. Buy some o2 bung extensions from Bruce ttm for the rears. Worked so far w me and have put 700 miles since my headers installed and no cel light.
Old Mar 3, 2012 | 06:23 PM
raleigh29's Avatar
06 CLS55, 03 BMW M3
Hmmm.. looks like I need to at least plug in the secondaries and try to code them out.
I will call Jerry on Monday to see what he has to say
Old Mar 3, 2012 | 07:18 PM
kustom2k1's Avatar
03SL55
I have the same problem and was told this was the solution as well.
Old Mar 3, 2012 | 07:29 PM
rchase's Avatar
2004 E55 (sold) 2012 E350 4M
How is the power difference? Worth it?
Old Mar 3, 2012 | 08:16 PM
Glyn M Ruck's Avatar
Super Moderator
Kleeman Cats require you to fit a set back spacer to desensitize the post Cat O2 sensor if I understand correctly. If not please educate me.
Old Mar 3, 2012 | 08:24 PM
skratch77's Avatar
2005 E55
you can run no cats at all and have no codes thrown if you send the ecu to them,they code it for free if you buy there headers.
Old Mar 3, 2012 | 08:49 PM
Super Moderator
Yes - I understand that - Thanks!
Old Mar 3, 2012 | 08:59 PM
c32AMG-DTM's Avatar
2008 A8L, 2002 996TT X50, 2009 X5
+1
"them, they, and [their]" being Kleemann, to clarify.
Old Mar 3, 2012 | 09:27 PM
jmb614's Avatar
E55 AMG
Can this be done with STAR as well?
Old Mar 4, 2012 | 01:22 AM
BBBSS's Avatar
03 E55 AMG, 06 Harley Road King Custom 06 Ram 2500 Cummins, 97 Firebird Race Car, 88 Cutlass Supreme
Is it not possible to build an O2 simulator that will always give the computer the reading it wants to see? These were quite popular in the late muscle car crowd till the EPA got mad at a few of the companies making them. There are instructions on how to build them online if you look around. Just plugs in and tells the computer what it wants to see as the post cat O2's only tell it if the cats are doing their job. Just plugs in and you zip tie it to something, it does not need to go into the exhaust stream at all.
Old Mar 4, 2012 | 12:36 PM
novae500's Avatar
W211
Yes that is what I have for my rear o2's. You can build your own for less than $20. Or buy them from a vendor.
Old Mar 4, 2012 | 01:45 PM
Robert AMG's Avatar
Cls63 & C32
Secondary O2 can be turned off and you can take them out with star diag, development data, control unit adaptation, variant coding, implizite codierung... item nb 183.
Old Mar 4, 2012 | 02:21 PM
jmb614's Avatar
E55 AMG
Fantastic! Thanks for the info!!!
Old Mar 4, 2012 | 02:24 PM
jmb614's Avatar
E55 AMG
I have a set of TTM's 90 degree extenders on the way. Not the same as a simulator but I'm hoping this will lower the amount of hydrocarbons the rear O2's see, essentially simulating the presence of a primary cat.
Old Mar 5, 2012 | 09:14 AM
raleigh29's Avatar
06 CLS55, 03 BMW M3
AWESOME info. Do the secondaries need to be plugged in to code this out or does it matter if they are totally unplugged?
Old Mar 5, 2012 | 09:32 AM
saleen01's Avatar
2004 E55
who sells these for our cars?
Old Mar 5, 2012 | 09:33 AM
novae500's Avatar
W211
Bruce TTM motorsports!
Old Mar 5, 2012 | 02:55 PM
zkeller's Avatar
04 E55
Thanks for the info. Will ECM coding changes overwrite my EvoSport tune?
Old Mar 5, 2012 | 04:08 PM
saleen01's Avatar
2004 E55
just bought some, thanks Bruce!
Old Mar 5, 2012 | 04:19 PM
Robert AMG's Avatar
Cls63 & C32
i don't remember, you can try.
No.
Old Mar 5, 2012 | 04:39 PM
TTMotorsports's Avatar
Former Vendor of MBWorld
Whatever we're tuning!
You are welcome Bob.
Actually you should be thanking Minh(novae500) too!
Old Mar 5, 2012 | 04:45 PM
zkeller's Avatar
04 E55
Thanks!
No.[/quote]
