80mm tb install DIY ?
Old Mar 6, 2012 | 03:39 PM
munich55's Avatar
E55 AMG W210 - sold, E55 AMG W211 - sold, CLS 500 C219 - sold, E63S AMG W212 - sold, C63S AMG A205
I need your help by installing an MB SL 80mm tb please.
There are still some threads but they are older in can't see pics.
My questions:
Is it possible to lift the sc just on the back without removing the fuelrail etc ?
Is it plug&play or must i chance some pins?
Thank you and sorry but in Germany nobody can help me :-(
That's all i have.
Do i need something else?
Thank you
Old Mar 6, 2012 | 06:17 PM
Forrest Gump 9's Avatar
shrimp boat
You definitely have to remove the supercharger to replace the sc inlet.
As far as changing the pins, try plug the 80mm unit in the car and see if it works.
Old Mar 7, 2012 | 01:54 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
My questions:
That's all i have.
Thank you
You need to remove the fuel rail, as there are bolts under it that hold the SC on. The SC has to come off , to change the inlet.
Most 80mm I ever saw had to have a pin swap. One easy way to tell, is to see if the throttle body blade opens the same way as your stock. If it came off and SL, then you may be fine..
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Mar 7, 2012 | 02:59 PM
grantwoodtx's Avatar
GLE 63S
My questions:
That's all i have.
Thank you
What are you doing about the bigger inlet in the TB?
Old Mar 8, 2012 | 08:45 AM
munich55's Avatar
I'm just a little bit worried about the install because I never removed the sc before.
The tb came off an SL 55 2006.
The part# is A275 140 00 04
Old Mar 8, 2012 | 09:25 AM
skratch77's Avatar
2005 E55
I will check my 80 but im 99% sure you need to swap pins and that tb does not have a opening for the oil vapor hose.
No worries and you can do a few things to make it work.
I would put a hose on the little y fitting and run it right to the inlet to avoid tapping the tb and dont try to take that cable off as its glued on the tb and you will damage it trying to take it out.
If you decide to not install it i would buy just your tb since i hacked mine up trying to get the cable off and started cutting the amg rubber part.mine wirks but i just want a clean one on the car.
Good luck buddy!!!
Old Apr 7, 2012 | 07:54 AM
munich55's Avatar
The tb is installed but the Car isn't Running corect.
I get errorcodes: p2032 and p2093.
So somebody knows which pins i have to change?
Old Apr 7, 2012 | 08:34 AM
Tech-Tune's Avatar
2006 CLS55 & 2002 SL55 (R129) Silver Arrow
1&4, 5&6
Old Apr 7, 2012 | 10:07 AM
munich55's Avatar
We tried it, but i get the Same Codes and Car doesn't run correct :-(
Is there an option to test the tb ?
Old Apr 8, 2012 | 11:22 AM
munich55's Avatar
I used the search.
The 1&4, 5&6 pin swap is for the 80mm tb with the part# A113 140 0104.
But i can't find it for the 80mm SL tb with the part# A275 140 00 04.
Car is still standing at the shop and nobody knows about :-(
Old Apr 8, 2012 | 02:26 PM
shrimp boat
First of all, disconnect the battery for ten minutes and see if the codes still there.
After you connect the battery and the codes still pop up, switch the wires 5&6. Good luck.
Old Apr 9, 2012 | 06:34 AM
munich55's Avatar
We used star diagnostic to delete the codes.
Tried pin 2-3 and 5-6 but we get the same errorcodes :-(
Should i trie just pin 5 and 6?
Old Apr 10, 2012 | 12:28 PM
munich55's Avatar
MB told me there is an new part# for the tb i have.
I is A 113140104
But i still don't know what to do?!
Can't get the car running :-(
Old Apr 10, 2012 | 04:23 PM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, GLE 400d, R107 280SL, Golf Polo
U sure u plugged the TB plug into the TB and not swapped the lead for the bypass valve ... Seem to remember they the same socket ...?
My 80mm TB was plug and Play ... Perhaps the pin swap had been done already ...
Old Apr 12, 2012 | 09:38 AM
stevebez's Avatar
you're welcome!
Old Apr 12, 2012 | 09:48 AM
munich55's Avatar
Stevebez thank you very much!!!!!!
You was right!
It was really the plug :-)
Thank you!
Old Apr 12, 2012 | 12:09 PM
stevebez's Avatar
Only reason I know is I had done the same thing and thot I had wrecked my car!
Old Apr 12, 2012 | 06:41 PM
AgSilver's Avatar
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
It's moments like this that make this forum invaluable.
Old Apr 12, 2012 | 09:15 PM
kustom2k1's Avatar
03SL55
Old Apr 13, 2012 | 07:04 AM
munich55's Avatar
This forum is really great !!!!
I don't know what i have been done without your help !!!!
