Parking and Standing lamps
So i had a "Parking and Standing lamps" bulb go out which in the manual it calls out a W 5W bulb. I went to the store and found a set of bulbs that were labled something like "2895 replaces W 5W bulbs" and they work just fine. The problem is that my normal driving low beam lights are a crisp white color (almost a light bluish tint but mainly white) and the W 5W bulbs are that nasy off white or yellowish color. Does anyone know of a bulb that i can put in there that will match up with my low beam light that are a crisp bright white?
So i would like some bright crisp white bulbs (so higher lumen rating) and then turn that function back on if this is possible.
(SOLD) 05 E55 Estate. 11 Golf TDi
no problem, I bought these.. for the city lights..
" iJDMTOY 360-degree Error Free 8-SMD-1210 T10 2825 W5W LED Bulbs w/ Built-in Load Resistors" item# 97985, they come in pairs.
and these for the license plate lights.
iJDMTOY Error Free 3-SMD-5050 1.50" 36mm 6411 6418 C5W LED Bulbs w/ Built-in Load Resistors For European Cars
Item number: 97986
www.ijdmtoy.com
Item number: 97986
www.ijdmtoy.com
SPONSOR/MBworld Guru
https://mbworld.org/forums/w211-amg/...leds-w211.html
https://mbworld.org/forums/e-class-w...ty-lights.html
The only way to disable/re-enable the bulb out is either through hard wiring or through STAR system reprogram.
Mercedes C300 Sport, BMW 745Li, VW Mk6 Golf TDI
Dealerships will have a STAR system computer on hand, but they might not be willing to do it. Some Mercedes specific aftermarket motorsports shops will have them as well. If you were in socal, I could recommend places to get it done, but have no idea in your region.
do you know about how much that would cost me?
