Supercharger belt tensioner.
2005 E55 AMG
Has anyone had their tensioner go bad? I have a decent amount of belt dust under the engine cover and my belt is brand new ( gates ). Is there a sure way to know if the tensioner has grown weak?
When facing the engine from the front, they are on the left side with hood popped up.
Check the baring on the front one as that can go also.
2005 E55 AMG
My pulley's are fine. It is my tensioner that feels like it could be weak. I don't have a car to compare it to though so I could be wrong. Is there a way to test the tensioning of the belt?
SPONSOR
Location: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
oh and on my 2nd tensioner...
2014 E63s amg 4matic, 2009 C63, 2006 E55 AMG , 2001.5 AUDI S4 stg 3+ w/meth
mine started making screeching noise at startup a few days before it broke off and sent my car into limp mode pulling out onto the highway trying to pass someone- that was fun lol
PLATINUM SPONSOR
Just the tensioner pulley but never a tensioner. I usually keep a few softly used tensioners around, just in case though.. Belt dust seems to be normal and it sticks around the tensioner area.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
