Car is dead.. ECU wont recognize Chassis.. help!!
This is for a CLS55, not an E55 but this section gets more traffic and the drivetrain is the same so I posted here.
I got my EC 172 pulley/Kleeman Headers/Tune installed last week and got the remote tune from Adam at EC.
Everything went fine on the tune but the CEL was still on for secondary 02 sensors.
Robert AMG posted how to code them out below :
'Secondary O2 can be turned off and you can take them out with star diag, development data, control unit adaptation, variant coding, implizite codierung... item nb 183.'
I brought it back to my installer to code out using SDS. It took the coding fine, but when the car started, we got all kinds of crazy lights.. ESP disabled, ABS disabled, etc..
After some troubleshooting, the ECU thought is was an E55 chassis so all the other electronics were confused.
He tried putting it back to a CLS (219) chassis, but the ecu just kicks him out and the coding wont take. Whats funny is he can change it to a E-class, and S-Class chassis no problem but the 219 chassis wont work.
My installer called Jerry and I guess he has a CLS55 with the same issue locally. This guy sent his ECU to Kory at Kleeman to code out the secondary 02 sensors and has the same symptoms when he put his ECU back in. Kory told him to buy a New ECU!
Anyone ever heard of anything like this happening?
I sent my ecu to kory and he was able to code it for me to pass emissions.
Maybe kick it back to kory to see if he can fix it?
Any contact info would help. PM me
It just seems really odd that they cant code the ECU. It's just 1's and 0's right?
EC and Kleeman need to get together and work this out. I assume EC is a authorized Kleeman dealer since they sell their headers.
He had Beckmann technologies try to remotely code the ECU.. they are stumped. FFFFFUUUUU!!!
http://www.beckmanntechnologies.com/index.php
Good luck.
Good luck.
Good luck.
Jerry out there? Any thoughts?
So you didn't send it to kleeman and had your guy do the coding?
car worked fine with EC tune except the issue of the CEL, which EC could have handled, but you choose to use your own guy to follow the instructions that some forum member posted on how to turn the CEL off. Now at this point you ran into issues.
Out of good faith EC can help you, but they are not obligated to on their part, regardless if some other car had the same problem under different circumstances.
Sounds like your installer picked the wrong model when he coded it....(root cause)
1. My CLS55- EC tune no problemo. CEL still on due to 02 sensors from Kleeman Headers. Bring to installer and try to code out with SDS. After removing item 183, ECU bugs out and wont recognize or take a 219 chassis code
2. Houston CLS55. A person here on the forums. EC tune no problemo. Send to Cory at Kleeman to reprogram for 02 sensors. Put ECU back in after Cory finishes his stuff. ECU bugs out and wont recognize or take a 219 chassis code
Worst case, I like what someone mentioned before and have the stealer flash it back to stock and then go from there. If stealer cannot flash back to stock.....it's not looking good.
Sorry for all your trouble. Jerry and Cory both some of the best in customer service. If they can help, they will.
You seriously won't be leaving any measurable performance on the table and no CELs. And no need to code the ECU for no rear O2 sensors.
