What the Fawk, how do I get this to fit?
Old Mar 14, 2012 | 12:20 AM
RedBullJnky's Avatar
you to Hate
Got a carbino air box and python tubes and can'y get it to fit with an 82mm TB fron Eurochgarged. Does any one know how this is supposed to fit? Do I have to shave the TB or what? Please let me know.
Old Mar 14, 2012 | 12:47 AM
E55amg/FD3S's Avatar
03 e55
Did you happen to purchase their intake that's made for the 82mm t/b. I'm thinking the intake is made for a stock t/b therefore not able to slide completely onto the 82mm. You might be able to port the inlet larger but I'm not certain if there is enough material there to port. First thing to do is verify you have the correct intake.
Old Mar 14, 2012 | 12:52 AM
adianaty's Avatar
E55, CTS-V Wagon, Duc 1098R
It looks like your adapter plate and TB combo might be to long since the box has no flex point. Do you have a picture of the TB side as well since maybe you can grind down the tab/stopper so that it seats deeper onto the TB.
Old Mar 14, 2012 | 12:55 AM
you to Hate
hold on
Old Mar 14, 2012 | 12:58 AM
you to Hate
like his ?
Old Mar 14, 2012 | 01:11 AM
xpl0sive's Avatar
CLS55 AMG
looks like you need to cut the inlet about half an inch, then it will slide on
Old Mar 14, 2012 | 01:18 AM
you to Hate
Thanks! We will get it on. But I need more power. you think this will help any?
Old Mar 14, 2012 | 02:00 AM
kustom2k1's Avatar
03SL55
"But I need more power" Elliot wants to go plaid..If the weathers good tomorrow going to hit PBIR!!
Old Mar 14, 2012 | 11:08 AM
you to Hate
http://www.youtube.com/watch?v=NP6DXoNKITc
I need new drag tires before I can go back to the track. Sorry dude!
Old Mar 14, 2012 | 11:13 AM
Hulk's Avatar
A Merc
Lol...hey bro let me know if u feel a diff or just cosmetic
Old Mar 14, 2012 | 02:33 PM
CharlyE500's Avatar
E55 2006 / CLS55 / S450 / Jag XKR2011
I wonder how much Hp will pick up with CF stuff..... 10hp to 15hp ? your car is already stage 3 + 550 injectors...... I think you have more traction issue than power issue.
Old Mar 14, 2012 | 04:19 PM
you to Hate
I'm going to redyno and see what the gains are from this. Who knows. Every little bit counts right?
Old Mar 14, 2012 | 07:59 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
I had the first adaptor plate ever made for an 82mm TB and CF intake and yes, had to cut the CF intake neck and port it out some.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Mar 14, 2012 | 08:06 PM
you to Hate
The CF intake is for an 82,but even my stock airbox sits very close to the fire wall. Rage-Tek should be able to get it on any way. Thannks!
