ESP cuts in unexpectedly?
There is no indication of a loss of traction / slipping / sliding although the car is under a very heavy lateral g just before this happens.
Something I just thought of could it be fuel starvation issue ? Where is the fuel pickup in the tank ?
Any other ideas ?
I'll let PLopes talk about his beast ... 168 pulley and he smoked all the 55's today !!!
Car is a freak with a Kleeman 168 pulley, headers, shelf tune, no cams, Renntech TB and airbox, TTM scoops, rear tank.
He is da man!
I managed 185.0 on my first run and did not break 180 after that ...
The next run I thought I would try with ESP off ... err never again as Paul will testify, car one way then the other almost ending in a proper mess, fortunately before I got to the long corner and straight. It was after this episode car went limp on me though mbe it was still in shock!!!!
Who knows. Felt like a fuel starvation, or a loose sensor tripping esp, did not feel like the blower switching off felt more like no ignition or no fuel...
I hope you find the problem.
If the steering angle sensor isn't centered then the traction control can activate what appears to be "early" in either a left or right turn (it'll only be in 1 direction, and most times high speed corners). This is usually because someone has removed the steering wheel and put it back on off-center and then the vehicle has been realigned to suit the new steering wheel position.
The wheel was one notch off centre recently and realigned by my MB tech at the recent service, I dont think a one notch misalign will cause this though? But there has been allot of fiddling with the sensor and the steering wheel so perhaps I get lucky and this is it.
I have not been abel to try is on a corner in the other direction but will try find one! car in bits though so its going to have to wait.....
If you can get access to SDS then you can check the steering agle when the steering wheel is centered, anything more than +/- 5deg is going to give you a issue but as long as it's less than +/- 25deg probably wont trip a fault code
So I would just need to reset the centering via Star or the battery reset method..and don't have to align the steering column tooth to the steering, or do they need to go back together in a specific alignment ?
gutted i couldnt make it, looks like it was a fun day
