Blow off valve issue?
Old Apr 25, 2012 | 11:03 PM
RACE_MX's Avatar
GLE55
I own a 2005 E55 with 20k miles and I am experiencing an odd issue. In 1st or 2nd gear from low rpms when I accelerate to approx 1/2 throttle the blow off valve goes off causing a hickup in the power delivery. Any input appreciated.
Old Apr 26, 2012 | 12:25 AM
Cylinder Head's Avatar
'19 E63S, ‘16 CLS63 RIP, '09 E63 Gone, '06 M5 Gone, '97 Supra TT Gone
Blow off valve?
Old Apr 26, 2012 | 12:32 AM
dchl21's Avatar
Gallado Spyder / AMG C63S / Cayenne
its normal. and sounds sexy as hell.
Old Apr 26, 2012 | 12:34 AM
Toadster's Avatar
2005 E55 AMG
you're probably experiencing what happens when the supercharger engages - does the car lurch forward (or buck) a bit?
Old Apr 26, 2012 | 12:38 AM
RACE_MX's Avatar
GLE55
When I step on the gas I can hear the blow off valve release pressure and the car loses power for a split second. It's very annoying.
Old Apr 26, 2012 | 01:41 AM
_AMG_'s Avatar
C63
Twin screw superchargers dont use blow off valves.
Old Apr 26, 2012 | 02:02 AM
RACE_MX's Avatar
GLE55
Originally Posted by _AMG_
Since when do twin screw superchargers use blow off valves?
Not sure - guess I don't know what I own. Thanks for contributing.
btw, your car is a terd.
Old Apr 26, 2012 | 02:17 AM
MBH motorsports's Avatar
Former Vendor of MBWorld
C63, SL55, E55, CLS55, ML63, C55
The 55k engine has a bypass valve sitting under the throttle body housing. It could be opening up for some reason. However if it is there would be a fault code (not CEL). I would check the fault code. It really could be a range of things From voltage issues, to spikes in intercooler temps. The list could go on without knowing if there is a fault code. You will have to seek someone out to read the fault codes.
The simplest thing to do might be to reset the adaptations in the car. Search for "sneaky ECU reset" there is a step by step walk through on how to do it. Or you can disconnect your battery for a while. None of these may help you, but at least its a place to start.
Old Apr 26, 2012 | 02:22 AM
RACE_MX's Avatar
GLE55
I took the car in and fault code said the intercooler thermostat was bad? This was replaced and the issue remains.
Old Apr 26, 2012 | 02:30 AM
You could have an intermittent intercooler pump. Not sure if that totally adds up though. I've seen these stock pumps cause some strange things in my day. Most of the time the car is down on power and intercooler temps are high. However I've seen a few other strange things manifest from a bad IC pump. Its very common for them to go out. In fact there should have been a worldwide recall on these Bosch pumps. They pretty much suck. Remember I'm not saying that's the issue you are having, but its a place to at least look at.
When the bypass valve opens up i'm pretty sure the supercharger disengages. So the could be something going on with the clutch.
Old Apr 26, 2012 | 07:47 AM
GT-ER's Avatar
2005 E55 AMG
If this problem occurs after more than one wide open throttle run then it's your intercooler pump.
Old Apr 27, 2012 | 12:40 AM
RACE_MX's Avatar
GLE55
No it's not after running the car hard. It happens all the time.
Old Apr 27, 2012 | 03:58 AM
justinwrock's Avatar
Ducati
Is the sound your hearing a chirp?
Old Apr 27, 2012 | 05:01 AM
dchl21's Avatar
Old Apr 27, 2012 | 08:14 AM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
No blow off valve on E55K.
What you hear and feel is the supercharger engaging. As you press the throttle and demand more power the supercharger comes on line and causes a 30-40 hp loss then in a split second the boost makes the engine produce much more power.
All E55K have this characteristic, it is normal.
Over 500 posts on the topic, don't worry every newbe asks same.
Old Apr 27, 2012 | 01:21 PM
CharlyE500's Avatar
E55 2006 / CLS55 / S450 / Jag XKR2011
You should go test drive other E55 to compare if the same.
Old Apr 27, 2012 | 03:38 PM
RACE_MX's Avatar
GLE55
Yes sounds like a chirp
Old Apr 28, 2012 | 03:31 AM
dchl21's Avatar
thank you... try to enjoy it... i really like that sound... it sounds like the beast is really powerful..
