2003 E55 AMG wont upshift after hard acceleration
Old May 9, 2012 | 12:06 AM
bstudey01's Avatar
2003 E55 AMG
Hi, I recently purchased a 2003 E55 AMG and have a question about the car, hopefully somebody can answer. I have noticed that after wide open throttle driving and then letting off the throttle completely the transmission will stay in the gear it was in for quite some time. It seems to take about 10 seconds or so before it will upshift and the RPM's come down, usually if I lightly press the throttle. I have it in sport shift mode. If I switch to comfort mode while the rpms are high it will generally upshift. Otherwise the transmission shifts great with no other issues. Is this normal for the "adaptive transmission"? Or is there an issue I should have checked out? Any thoughts would be greatly appreciated
Old May 9, 2012 | 12:07 AM
lfe136's Avatar
2006 C230SS, 2007 e63, 2009 gl450, 2003 Ducati 749
Normal
Old May 9, 2012 | 12:09 AM
AWOL's Avatar
e55
just tap the shifter over to the right and it will upshift
Old May 9, 2012 | 12:11 AM
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
Doesnt the TCU tune get rid of the delay in shifts?
Old May 9, 2012 | 12:12 AM
bstudey01's Avatar
2003 E55 AMG
Thanks I didn't think it was an issue but have never driven a automatic that acted this way, I actually like it, reminds me somewhat of a manual and don't have to waste time upshift and downshift again if I want to get back on the throttle hard again
Old May 9, 2012 | 12:15 AM
berti_00's Avatar
2016 Cls63s AMG
normal
Old May 9, 2012 | 02:48 AM
BBBSS's Avatar
03 E55 AMG, 06 Harley Road King Custom 06 Ram 2500 Cummins, 97 Firebird Race Car, 88 Cutlass Supreme
Yeah its setup that way in case you had to hesitate for a second for whatever reason then get on it hard again. If it upshifted then downshifted again real quick its hard on the trans.
Old May 9, 2012 | 06:56 AM
grantwoodtx's Avatar
GLE 63S
He NOT talking about a delay in shifts all the time, only after a romp at WOT!
OP this is normal as the transmission assumes you may want to do this again so it optimizes the gear to give you the best acceleration possible.
Old May 9, 2012 | 07:14 AM
GregMB's Avatar
Normal....
Take a look at the following video for an explanation of speed shift, etc (starts around 1:40)
-G
Old May 9, 2012 | 10:28 AM
Toadster's Avatar
2005 E55 AMG
do the ECU reset and see if it improves...
