--ESP OFF-- is trouble
So the Quaife has an adjustment on it you turn to set the proper contact pattern instead of using shims your saying? Your post kinda made it sound like you just plop it in and don't have to adjust anything. Wanted to make sure people understand it still needs to be adjusted weather with a built in adjustable "shim" or with different thickness shims you just slip in with the diff.
You will always have to make some sort of adjustment to get the best contact pattern when installing a new diff unless you get really lucky and tolerances are perfect out of the box. Haven't seen that happen yet. I always use marking compound and spin it around and check the pattern and adjust from there.
Actually with the Wavetrac you have to buy a 20 c-clip kit since they move to set it up by changing the thickness of the c-clips. I have installed over 50 Quaife LSD's in Mercedes Benz's and they are all a direct drop in and no type of adjustments is necessary.
Your saying you can take 20 cars, and 20 random Quaife diffs and install it in each car and every one will have the exact same and proper thread contact pattern?
I'm sure AMG and Benz have tighter tolerances then other manufacturers, but there are too many tolerances stacked that come into play with thread pattern. The housing itself, the dif, the gears all come into play.
Getting a proper pattern using marking compound and makinng adjustments is how installing a diff properly is done. Weather you use shims, or if the diff has an adjustment built onto it. Short of getting extremely lucky one time, you shouldn't just slap a diff in a car and call it good. Your asking for gear noise issues, extra heat, possibly broken teeth, or the teeth killing each other and taking out all the bearings in the axle.
Again, maybe I misunderstood your post somehow? Did you mean to say you just drop this diff in, bolt the caps on and go with zero adjustments at all?
Here's a good example video.
looks like the Quaife's have come way down in price too,i've seen them as low as $900,where the Wavetrac seems to be $1095 everyhwere.
I have no horse in this race, I'm just a car guy that's been building cars with his own two hands for years as well. Just my honest opinions are given here with zero bias. My .02
i've been reading and reading about the Quaife and the Wavetrac and honetly this is the first time i've read anything about the Wavetrac being more difficult to install.
i really want the Wavetrac as i people seem to think it's overall better,but didn't want to pay several hundred more in labor either.
Thanks for the info BBBSS
