Transmission flush at dealer, now car wont move
I have also done flushes without verifying the maintenance history of a car (approx 60k on the odometer). End result was a transmission replacement due to harsh engagements, followed by total failure due to excessive wear of the clutch discs.
By the way, the fluid I used was 001-989-68-03-10, not the 13 oil you have on your invoice. That may be the latest oil, but i went by the info below.
Date: September 1, 2011
Order No.: S-B-00.40/89b
Supersedes: S-B-00.40/89a, August 10, 2010
Group: 00
Revision b: Added exception note.
SUBJECT: MY-All, Models All with Transmission 722.6 or 722.9
Operating Fluid Specification Changes for Automatic Transmission
5-speed automatic transmission 722.6
Only use the transmission oils outlined in specification for operating fluids sheet 236.14.
See WIS document: BB.00.40-p-0236-14a.
MB part number-A001 989 68 03 10
7-speed automatic transmission 722.9 up to transmission production date June 21, 2010
Only use the transmission oils outlined in specification sheet 236.14
7-speed automatic transmission 722.9 after transmission production date June 21, 2010
Only use the transmission oils outlined in specification sheet 236.15
See WIS document: BB.00.40-p-0236-15.
MB part number-A001 989 78 03 09
I believe Skratch had a similar scenario and posted his solution - relatively easy and inexpensive fix....
Flushing and replacing fluids are two different things.
115k miles IMO is decent miles and about time for trans repair, especially if you lay into her often. Mine went sound a tick over 100k and to be honest I wanted it to go, this way I no longer have to worry whether it will go bad or not.
Noticed PP has a filter/gasket kit for $7.00, great price. Not sure the brand, I picked up a few BAR filter kits a while back on Amazon.
http://www.performanceproducts4benz....2-6-trans.html
The only reason the 722.6 requires a flush is because Benz removed the TC drains in 1999 to save money. Put them back in 2006/7. The converter holds over 4 litres of fluid.
If one does the 14 quart Benz hand flush per WIS method with 236.14 fluid & work cleanly you will have zero issues. It's done thousands & thousands of times in ROW. Only MBUSA was dumb enough to say filled for life. Filled for life = short life!
Fluid must be changed EVERY 39K miles or 60K Km's as in ROW. In an AMG driven hard more frequently would be prudent.
Never flush with anything other than the approved fluid. Never use high pressure machines. All you require to do is displace the fluid in the TC & cooling circuit with a hand pump as per method.
After change these boxes require some mileage to auto adapt to new charge of friction modifiers in the new fluid or one can reset all adaptions for each clutch pack with a Star.
If a transmission fails after doing a proper service it would have failed anyway. All that can cause clutch pack failure is the wrong fluid with the wrong frictional properties, lock up pressures wrong or abuse.
236.14 fluid is now mandated for all 722.6 transmissions.
Personally I would not run the newer Benz fluid in these trans. It works fine, just the shifts are not as pronounced.
https://mbworld.org/forums/w211-amg/...uild-pics.html
Royal Purple have no approved fluids & should not be used.
You can read this if you are interested. The whole viscosity thing is a red herring & is done for energy saving. The latest 236.15 Blue fluid is considerably thinner & not reverse compatible. It is for the 722.9 Plus transmission launched in August 2010.
https://mbworld.org/forums/clk-class...722-6-atf.html
Read up. The RP formula did not change, just that they tested and updated their labeling to reflect 236.10/11. The older label only went to 236.9. The Shell on the other hand is the thinner formula and works to 236.14.
I like the shifts just the way they are, simple as that. Will not run the new fluid in my car.
I'm strange that way.
If you are not saying the above and are saying Royal Purple doesn't have 722.6 fluid (or 236.14), well then I will also say that is wrong because I have had Royal Purple fluid in my transmission bought from Advance Auto Parts and Pep Boys auto parts stores here in the U.S that said approved for Mercedes Benz 722.6 on the back about 7 months ago so they do offer the fluid for our transmissions.
Edit: And after looking at the link provided above my post I see they now have the listing of the newer 236.14 you mentioned Mercedes says to run so they certainly have approved fluid and can be used.
As I understand a transmission flush and transmission service are 2 different things.
I did mine at 62k Miles and now its' 5 years later and I'm at 101k. What do do
Most people consider that 236.14 gives slightly greater shift shock than 236.12 & older which are now all obsolete. Time moves on as does development. Once adapted shift shock is identical & maintained for longer with 236.14. One of the fluid design parameters.
DG - fyi. WIS change & flush procedure.
https://mbworld.org/forums/attachmen...0flush1-1-.pdf
https://mbworld.org/forums/attachmen...0flush2-1-.pdf
You can ignore all you want others that have posted about softer shifts with the newer THINNER fluid all you want, however I would like to think that perhaps they would know their own car better than I know their own car. With all respect, you have not stated anything of substance that remotely would change my mind.
I've been involved with the Benz approvals programme my entire Oilco career approaching 40 years. Benz have a fabulous testing regime. Labs far better than anything Royal Purple have - in fact Royal Purple have no real research facilities - You need to go to a major for that. The cost of running our research labs exceeds Royal Purple's annual turnover many, many times. Benz works long and hard with the oil industry to look after their products & customers, much as Cat do for Earthmoving. Their approvals process is completely legit.
2nd transmission services done yesterday. The 1st services were done @ 35K and 2nd done @ 65K miles.
I am not disputing that the new fluid has more friction additives or other improvements, I am not agreeing to it either. However we are not talking about a little slow 350 here, these are high powered cars and the transmission is simply not going to last 1,000,000 miles. Period. You see, over here, in this forum, we are not running 15 second cars.
Most here want stronger shifts. Your deliberate attempt at ignoring the end users complaints on shift quality is exactly indicative of what people complain about with Mercedes dealers. "Customer is wrong, dealer thinks they are always correct. " How do you know how the RP will test out as according to the one of their techs I spoke with last year they never submitted to Mercedes for testing as Mercedes charges 'ridiculous' fees. For someone to state people should not run a particular fluid because they know nothing about it is downright wrong.Should I not run certain premium fuels in my Mercedes because Mercedes has not tested them all either? Does the pump need to state 'Certified by Mercedes' before I decide to pump the gas?
