Is my M113k modded??
Earlier I was looking at different tuning companies who offered packages for my M113k motor. I came to the conclusion that the best bang for your buck is eurocharged. As a reference I was comparing the numbers to my dad's sl65 and it seems that I could get pretty close to his horsepower rating for under 2k. Then it occurred to me that my car could already have a tune and/or pulley.. It keeps up pretty well with the sl65 and smoked my mom's s600. What I'm asking is if there's any way to tell if I have a tune and/or pulley?? The dealer I bought the car from said that it had mods, but I never got a straight answer on what. Just FYI the car is a 2003 s55. I'm pretty active on the benzworld forum, but nobody messes with the m113k engines as much as you guys on the e55 mbworld forum (which is why I'm posting over here). Any help or tips would be great! Thanks
like everyone else said, post up a pic of the pulley and we can tell ya if its aftermarket...
I'm tuned and still can not rev past 4K in park.
The part number on the supercharger is: 155 090 04 80
Just kidding
The actual part number is:A 113 090 02 80
And the throttle body is : A 113 141 06 25
Now, if you were able to hang around with your dad's sl65, then after mods his will hardly hang around with yours
Of course, most of the other control units must be changed with star otherwise you get errors.
I searched and searched for something talking about this on google, but can't find anything. As far as I know, I'm the only one who knows about this.
The other thing is, on my brother's 2006 S500, I can enable the cylinder shutdown feature that was on the 99-02 S600's.
Also, the fact that you can't even tell if your car is modded even by the clearly stock headers and crank pulley probably tells me that you know less about your car than you think.
There's plenty of good info here. Use it to your advantage and mod right. A tune isn't that expensive and can be adjusted (properly) with each level of mod you have.
Good luck!
Good luck!
Believe me when I say that the way your car is now, tuned and untested, is more likely to crap out cyl-8 or something else than a proven tune from Kleeman, OE or EC.
