E55 Down
i wonder if we can somehow blame this on the RTR pulley? lol just kidding, sorry about ur misfortune, hopefully you can find a low mileage engine in Houston and drop that baby in.
'06 E55
Thanks, guys. The car has only 49k on it and the engine went no ***** 500 miles after my warranty expired!
I did forget to mention that I have an 82mm throttle body in my mods list.
On a happier note, I met some of the Houston crew tonight. They seem like a really fun bunch, like you'd expect. Dinner outing is Friday night!
#33
SPONSOR
Location: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
damn! sorry that sucks! If there is anything we can do to help get you back on the road just ask!
And watch out for the houston crew...lol They are a handful!
#34
Not if done properly....One should NOT be JUST tuning WOT, especially if adding injectors....It would really be interesting to know what his open and closed looped logs looked like....
#35
CLS55
#37
1 Post
05 crossfire w/SL55 drivetrain installed by Rudy Compart Intake/Needswings best et-10.76 @ 129
quote:Mods were LT headers, 180 crank pulley, upper pulley, TTMOTORSPORTS fuel rail and injectors, heat exchanger, OE Tune. quote: Sorry to hear you lost your engine, hope you get it back on the road very quickly.
I am Very suspicious of running the two pulleys. Also doing a poll in fifth gear, even at half throttle,Is something that I would also question. Anyway I hope the tech finds out what caused it. Good luck jim
#38
In fact that was a good question. He had the smaller SC pulley upgrade and from we know, you need to tune that thing for the extra boost. For any 55K owner should be concern the cause of engine failure. 180 crank pulley + SC pulley = 195mm pulley power band.
#40
Dennis, what MPH did you do the 5th gear pull up to, and do you think the car could have still been pulling boost on desceleration? Boost, with no fueling due to descelerating after the pull would cause copious amounts of heat, and detonation, ultimately catastrophic engine failure. This would lead to the white smoke you saw immediatly after the run.
It will be interesting to see what the internals look like if you decide to open the motor up. Top piston damage, holes, would be expected if this is the case.
#41
2005 E55 AMG
#43
93' Ultrasonic Blue Mica LS6/T56 RX7 R1 weekend/ 2007 4Runner V8/ 08' prius
Anybody can tune a vehicle at full throttle, it's when the tuner does part throttle street driving is when you find good tuners especially on F/I cars. During part throttle, the engine can lean out but normally it doesn't cause damage. If the vehicle is under load, high rpm, part throttle, bad gas etc., under the correct circumstances there is a chance of catastrophic engine failure.
#44
Sorry to hear about your car man. I know how it feels to lose the BEAST. Good luck with whatever you decide to do with the car.
#46
2005 E55 AMG
#47
'06 E55
From what we could tell, it looked like rings. Until I get the car somewhere and get the heads pulled, I won't know for sure. The piston did not look melted, but it wasn't the clearest of bore scopes.
Doing some drinking now in Houston.
