did the split today.
Rating: Thread Rating: 5 votes, 5.00 average.
Old 08-31-2012, 05:07 PM
99lightning's Avatar
99 ford lightning
I had cb tuning do the intercooler split today. I have this routed the way i did on my lightning big difference in temps. I compared it to another e55 there with a johnson pump and big heat exchanger that car has a pulley though very close in temps on this hot day.
Old 08-31-2012, 05:15 PM
JDMAP1's Avatar
W222 S550, W218 CLS63, W166 ML550, Titan, Sentra
what exactly is "intercooler split" ?
thanks
Old 08-31-2012, 05:16 PM
Former Vendor of MBWorld
shardul's Avatar
2003 W211 E55, 2003 W220 S600
isolate the engine coolant from the s/c cooling system i.e. stop engine coolant from mixing with s/c coolant
Old 08-31-2012, 05:49 PM
93RX7LSX's Avatar
93' Ultrasonic Blue Mica LS6/T56 RX7 R1 weekend/ 2007 4Runner V8/ 08' prius
When you guys split the system, do you still run coolant for the heat exchange? Why not run straight distilled water? It dissipates heat much faster than mixed coolant.
Old 08-31-2012, 07:37 PM
99 ford lightning
yea show me the difference when its 92 out
Old 08-31-2012, 09:59 PM
FASN8N's Avatar
CTSV/6sp Grocery Getter
Will you give us a diagram and parts list please?
Donny Linton (11-19-2019)
Old 08-31-2012, 10:27 PM
cal1's Avatar
SL55, ML500 & Acura TL
He is dead right, but who knows if it is measurable anywhere other than in a lab. Pure water plus a surfactant (water wetter) absorbs heat better than virtually any substance. Keep in mind, pure water is also aggressive. Meaning it likes to dissolve stuff. For instance the metals in your system.
If you are looking for tenths or 100ths at the track, run distilled water and some water wetter. The rest of the time, run some antifreeze for corrosion protection IMHO.
Old 09-01-2012, 05:16 AM
99 ford lightning
if anyone is out east here you can contact me about the intstall for this at cb tuning. They have done them before but using the bmw tank. But I wanted a return on mine.
Old 09-01-2012, 09:12 AM
cij911's Avatar
one car at a time
Can you post the specs on your reservoir ? It looks like you used an overflow tank, but it would save a lot of time for all of us, if you posted the part number. Thanks in advance
Old 09-01-2012, 10:52 AM
lowprofile's Avatar
E55
Looks like a stock Mustang Cobra reservoir, '03-'04. I would prefer this over the BMW reservoir as it would be self bleeding.
Old 09-01-2012, 11:38 AM
cij911's Avatar
one car at a time
Looks like it is less than a quart of fluid. Do you think that would be very beneficial ?
Old 09-01-2012, 06:21 PM
DVC
DVC's Avatar
'06 E55 AMG
Did you datalog your IATs at all before you did the split?
Old 09-01-2012, 07:46 PM
shardul's Avatar
Here are some pics of the connection that has to be altered. It is located on the lower right hand side area of the radiator. After every thing is done make sure that none of the hoses are touching the alternator pulley.
In stock form
Undo top clamp and close the barb as shown in the pic
Attach a 3/4 inch barb on this end. One end of the bard will go into the factory tube the other end will connect to the reservoir. remember the reservoir is only a fill point
View from top
Old 09-02-2012, 02:21 AM
pearlpower's Avatar
E55 w/ goods, Z32 Project underway
The clamps are a PITA even with 12" snips. I use a Dremel being careful about depth and surroundings, bam, done in no time.
Good thread here
https://mbworld.org/forums/w211-amg/...tructions.html
Old 09-02-2012, 05:07 AM
99 ford lightning
its a 03-04 cobra res. works perfect as it worked perfect on a 10.88 unported eaton powered cobra we had. Recovery now is wayy better, 40-50 deg drop in temps i had a weak pump to start with too. after a highway drive the tank is not hot i couldnt touch the bmw tank on the other e55 after it was driven to the dyno the other day.
Old 09-04-2012, 11:36 AM
lowprofile's Avatar
E55
Of course the BMW reservoir is going to be hot. It's just a fill point to bleed the i/c system. Water does not actually circulate through it, so it is going to soak up the radiant engine heat.
Old 09-04-2012, 02:04 PM
99 ford lightning
well my cobra tank wasnt it works i have the real data with stock he
Old 09-04-2012, 04:45 PM
chawkins2001's Avatar
2006 E55 AMG
Here we go again
Old 09-04-2012, 04:53 PM
99 ford lightning
this doesnt happen on the L boards lol.
Old 09-04-2012, 05:00 PM
2006 E55 AMG
Just pulling your leg homey
Are you on lightning rodder much? I really miss my lightning that I sold, they are such unique vehicles. True TQ monster sports car in a truck shell
Old 09-04-2012, 05:43 PM
99 ford lightning
just under general chat, alot of them like the e55, or if someone has a magnum powers issue. yea those trucks can be nasty as hell.
Old 09-04-2012, 09:49 PM
lowprofile's Avatar
E55
You took what I wrote all wrong. I'm sure the cobra reservoir works well for you.
Old 09-04-2012, 10:19 PM
pearlpower's Avatar
Perhaps because that board has a built in translator.
Seriously, how about posting up your #s?
Mine with the new FT-P/Dads tank will get posted up Thursday. Now running WW and distilled for new results.
Old 09-06-2012, 03:12 PM
E55amg/FD3S's Avatar
03 e55
Looking forward to this thread. Will be installing mine soon!
Old 09-07-2012, 12:07 AM
HouMike's Avatar
2005 E55; 2006 750i
The lightning and Shardul. Doing this soon as well. Looks much cleaner than BMW solution and if I understand provides circulation as well.
You have already rated this thread Rating: Thread Rating: 5 votes, 5.00 average.
Quick Reply: did the split today.
