Official Weistec M113K 3.0L Supercharger, PICTURES INSIDE!!!
#276
......before you throw away your AMG s/c.....wait! Are the Weistec figures not achievable in heavily modded cars with stock s/c? Lets stick with actual figures, not projected theoretical figures. If Weistec thinks there s/c can make more power with more mods, then they can always post actual dyno figures with the additional mods
Ted
Ted
#278
2005 E55 AMG
Ted
Ted
#279
05 White Pano E55, Cadillac CTS-V
Ted
Ted
Now here is the problem with that though, they can only do that using C16 or Q16 race fuel and can only do that for one run with the car cold and/or with a tank full of ice and perhaps with their exhaust missing from the car and then they sit for another 45 minutes with fans and bags of ice all over their engine to achieve that number again. As you see, there were a lot of "ands" in that.
So in a "real world" scenario driving your car as you would daily like a normal person, it just doesn't seem to be possible. Where we have near 600whp being produced on 91 octane with the upgrade with only more room for improvement for the guys that have or are willing to get cams and or ported heads on top of any benefit running a higher octane (93) may also bring to the equation.
So while I definitely see where you are coming from because these numbers from Weistec are nothing amazing and not seen before, at the same time they are when you take in to consideration the things listed above. Over 600whp on pump gas seems easily attainable if you have all the basic mods. Those are my 2 cents.
What I want to know is what the difference was in the car producing the 574whp on the dyno in the video Weistec posted which with the same mods they give us the graph of 534whp? Did they tame back the timing a few degrees, was that high run with ice in the tank? What was done that only a throttle body upgrade made basically the same as the most recent headers/exhaust also added dyno for that video?
#280
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
Our E55's were more than that in 2004. Remember: Nothing accelerates faster than the depreciation of an AMG! Just check the prices of a year old SLS. A good E55 by the spring of 2015 should still bring $18-20K and I'll bet you can find an E63 TT in the $60's by then. These things will be coming out of Alfalterbach like popcorn. And, thousands upon thousands of standard E Class's are destined as taxis. There's an E63 (big block) taxicab running around Mainz Germany.
#281
Dirt Scooters
This is true, there are people making 575whp or 600whp with the stock supercharger using a big crank pulley and cams and or ported/heads.
What I want to know is what the difference was in the car producing the 574whp on the dyno in the video Weistec posted which with the same mods they give us the graph of 534whp? Did the tame back the timing a few degrees? What was done that only a throttle body upgrade made basically the same as the most recent headers/exhaust also added dyno?
#282
Yeah, and when asked why the video with only 82mm throttle body showed a higher number (574whp) compared to the graph posted with only 82mm throttle body (534whp) Weistec said:
So if they left 40whp on the table from their advertised number (their graph) and what the car was able to actually do, then what did/could the car do with the headers/exhaust if the advertised number was 575whp? I am pretty sure it would be over 600whp as it sits. I just want to know what the difference was for the two throttle body numbers, was it a tune adjustment?
We always advertise conservative numbers, but posted a video of what we were able to get out the car on the dyno. Those familiar with our other products know we don't over inflat advertised power numbers. This video was to show the high power capability on a stock car.
#283
Just look at the platform you would be starting with in an E63TT AWD. These are most likely lighter as a result of extensive usage of aluminum and 800 hp is possible just with the ECU. The technology is a light year ahead not to mention the launch control capability. IMO, these are easy 10.0 sec missiles - - - and eventually into the 9's.
My thoughts would be to sell off the E55 to the youngsters in about 18 months and let the development begin on the 63TT's.
#284
Probably 800 hp is possible, but at what cost and then what do you have?
#285
....the plus 178HP car has full exhaust including headers, no Cats and an 84mm throttle body and running 17psi of boost. This is already a heavily modified car. For me I've been around the block. Until I see the numbers, it doesn't exist
Ted
Ted
#286
I've yet to see a ecu tune only 63tt make 600rwhp, where do you come up with 800hp? Now if you mean crank HP, 700-800rwhp in a e55 is not going to be comparable to 800 crank HP in a 63tt. I think if we can get these bigger displacement SC going on full modded cars you'll find out that the 63tt isn't so impressive when 55 are running 9's Also wait until everyone finds out what it cost to actually put larger turbo's on the 63tt, it'll make this SC get look like it was made for a Civic!
http://www.weistec.com/m157s1.html
Weistec is well over 600whp with tune only and simply air filter swap.
My guess is that we will see an 800whp TT before we see and 800whp 55K
Hope I'm wrong though
#287
Here ya go:
#288
There are several companies working on this already.
The TT12 is designed the same way (and just about every other performance turbo car out there now) and there are upgrades available for the V12.
In my mind the bottom line is that these new motors have greater potential for performance than the 55k. Therefore getting turbo upgrades should happen fairly quickly...especially consider the guys in places like UAE throw tons of money at their cars looking for huge numbers.
I think mod for mod: upgraded FI, head work, 20+psi and full bolt ons the TT is going to develop more power.
Oh and add AWD with upgraded drivetrain and she will be stoppable...lol.
Hello 8's :-$
#290
My E55 will outlast me as my end is far closer than my beginning.
#291
If you have not already seen this, you will find it, at the very least, informative. You will also see what tuners have as a base to start from.
#292
Also tells me guys running big pulleys and oem exhaust (or a restrictive one) are looking for a bucket full of broken pistons....
#293
2005 E55 AMG
My thoughts too, I guess given there is now less exhaust back pressure meant more heat was being scavenged away and less heat was being internalised by the "open" exhaust. Less prone to knock onset on 91 fuel, so they could safely up the boost.
#294
Former Vendor of MBWorld
Gentlemen, our supercharger is configured differently depending on modifications. A free flowing exhaust will drop boost down, but we offset this with a different upper pulley to compensate. Because of the increased efficiency of a high flow exhaust system, we can safely increase the boost pressure. Thanks again!
Weistec Engineering
Weistec Engineering
#297
2005 E55 AMG
Weistec Engineering
Weistec Engineering
#298
E55, CTS-V Wagon, Duc 1098R
17psi is a 200-205mm crank pulley on our cars boys so keep that in perspective guys.
Weistec, are you at a point where you are using a map clamp or is the ecu still managing ok at these boost levels? Previously anything over 16.5psi was a known cliff in the ecu.
#299
