Transmission adaptation
Rating: Thread Rating: 2 votes, 5.00 average.
Old Sep 3, 2012 | 04:50 PM
PACougar's Avatar
1000Hp Diesel Trucks, 2019 E63s
Has anyone figured out how to get the tranny adaptation to run if your car is always above the torque thresholds?
Old Sep 3, 2012 | 05:11 PM
pearlpower's Avatar
E55 w/ goods, Z32 Project underway
I was under the impression the TCU flash solved this.
Old Sep 3, 2012 | 08:58 PM
PACougar's Avatar
It removes the torque managment limits. However that has no effect on using SDS to run a Trans adaptation.
Old Sep 3, 2012 | 10:06 PM
pearlpower's Avatar
Not sure I understand as I had no issue using SDS for adaption.
Old Sep 3, 2012 | 10:38 PM
adianaty's Avatar
E55, CTS-V Wagon, Duc 1098R
I used this after resetting through SDS. Not sure if it is what you are after but notice that it needs the AC off even to get to the right torque values.
http://www.scribd.com/mobile/doc/91972241
Old Sep 3, 2012 | 11:09 PM
skratch77's Avatar
2005 E55
I have a rough downshift from 4th to 3rd when I use very little throttle,like 3% and if I give it no gas it will down shift smooth and anything over 5% gas it shifts smooth.
I have been trying to get this adapted with no luck and just learned to give it a little more throttle if Im about to go up a hill and the car is in 4th and about to downshift to 3rd.
it only does this going from 4th to 3rd on very light throttle.
can this be adapted out or should I try to get an updated tcu from the dealer
Old Sep 3, 2012 | 11:56 PM
PACougar's Avatar
I think the 3.55 in the back are why it won't allow me to run the adaptation and yes the TCU has been updated for the gears. I think I'm beyond the torque limits for running adaptation.
Old Sep 4, 2012 | 01:46 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Sounds like your in new territory. Have you gone back to your tuner to see if he can customize it for you?
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Sep 4, 2012 | 01:56 PM
chawkins2001's Avatar
2006 E55 AMG
Hold on a second, you have 3.55 gears in your E55?
Old Sep 4, 2012 | 09:52 PM
PACougar's Avatar
Yes I have, but he doesn't have any way to do it. Hopefully I'll figure something out, but it doesn't bother me that much.
Yes Craig I do
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
