[GunMoto's] '05 Pewter W211 E55 | First PICS
Thanks bro! We need to hit up one of the car shows this spring/summer!
I ended up just using 3M double sided tape, it was the thin gray version. So yeah, it took some time cutting thin strips for each emblem, lol.
- Retrofitted AMG 63 paddles; with the helpful guidance from Chris (latemodel21).
- OEM glovebox tray.
- Smoked taillight clears.
- Retrofitted OEM rear door shades.
- OEM cargo rail.
I definitely want to do the diffuser, facelift headlights and paddles.
Do you do side work? I'm local! haha
Also I see a Crossfit858 sticker... then you probably know my friend Chris Figs huh? LOL.
It's so much more convenient to not have to physically connect my iPhone each time I get in the car.
Product info:
http://www.viseeo.com/ugC_ShowroomIt...0&hidShowID=15Haha, thanks bro!
I discovered there is an accessory kit available for GLs & MLs that did not have this cargo rail system factory installed. The cargo rail is instead secured to the edges of the trunk floor (as opposed to the permanently installed tracks). I had to modify the clips as it was originally designed for a much thicker (GL/ML) cargo floor board.
PM me if you need more details.
Original:
Modified:
Lolz, I most def know Christian!!
Question:
Do you have more shots of the smoked tails? That would look great on my Flint. Also, where did you purchase? Are they just film or did you replace ?
I'd love to see a few different angles to see how it looks in different lighting.
Again, car looks awesome!
Amazing car, I will strive to make my pewter E55 as nice.
www.ebay.com/itm/190815587440
Because we don't have the "standard" style rear view mirror stem, I secured the mount to the plastic panel covering the rain/light sensor (and cut off the excess length from the set screws). You can "pop" the panel off to remove, and "snap" back into place to reinstall.
I also picked up the Viseeo Tune2Air bluetooth module on eBay, here:
http://www.ebay.com/itm/130953584801
Universal V1 mount, modified and secured to rain/light sensor plastic panel:
Thanks Toad! Question:
EDIT: There's also the option of using a "light' smoke if visibility is a concern.
I had my V1 hardwired to the cigarette lighter, and it would power on about 90% of the time. I think it's something related to the cigarette lighter being a "convenience function," and if you're charge is not sufficient (or, ideal), then power will not be supplied and will usually finally power on the V1 following 10-20min of driving.
I just recently re-wired the V1 to the rear view mirror power supply and I haven't had any issues with the V1 not powering on, so hopefully this resolves the issue. I believe the rear view mirror is part of the "Overhead Control Panel" function, which likely has more priority in supplying power, compared to the cigarette lighter.
Sickness
Your car looks amazing and is giving me ideas.
