Please Help!
My car is stock. I have am having the following done at the shop...
Left Side (Driver's) Fuel Sending Unit and Both L&R Seals
Engine Mount
Trans Mount
Left and Right Thrust Arm w/ Alignment
Brake Fluid Flush
and a ECU Tune (they re-flashed the ecu to stock to rule it out)
Please help!
Thanks,
Steven
I'm curious to hear what part numbers you end up with for this replacement sender.
I have heard that with the newest design sender, you will be forced to buy BOTH sides as the new parts are not compatible with the old ones. The seals for those senders are new design also....
Hope this doesn't trigger fuel leak issues for you. Please post up the part numbers that you end up using for the fuel system repair.
-G
-G
211 470 51 94 - Driver
211 470 17 94 - Passenger
And can you confirm if they need to be done together? Mercedes told me that it's not necessary...
