Front Suspension Clunk Making me Batty!!!
Old Oct 12, 2012 | 11:51 AM
kurtwz's Avatar
2005 E55 Sedan (Peuter)
I have a heavy clunk sound in the front suspension on both sides. Sounds like metal. I’ve inspected the suspension and haven’t found any visibly worn, so I think now it’s the wheel bearings. Not sure about that, tho. I did the “push-pull” test on opposite sides of the wheel and got a very small amount of play. The edges of the tires may have moved 1/16” to 1/8”, but not more. Does that indicate bad bearings? The car rolls along quietly , but I just don’t know what else it could be. Also, I have the Arnott air struts on both sides in the front. Anyone have a clunking sound with those installed? The sound is over anything small in the road. Doesn’t have to be a speed bump. Can be as small as a 1” crack in the road surface for it to make the sound. Any advice on what the root cause of the sound could be would be greatly appreciated!!
Old Oct 12, 2012 | 12:12 PM
nizzle's Avatar
2014 AMG E63S, 2006 XK8 victory edition convertible, 2006 supercharged trailblazer SS, 2001 E430
Ball joints maybe?
Old Oct 12, 2012 | 12:21 PM
93RX7LSX's Avatar
93' Ultrasonic Blue Mica LS6/T56 RX7 R1 weekend/ 2007 4Runner V8/ 08' prius
Originally Posted by nizzle
Ball joints maybe?
+1 check upper and lower and maybe tie rod ends.
Old Oct 12, 2012 | 12:32 PM
desired_speeds's Avatar
2007 SL55 AMG
does the noise go away or change when you drive the car in raised mode?
Old Oct 12, 2012 | 01:33 PM
kurtwz's Avatar
I haven't checked that. Why, what would it indicate? I'll check that tonight.
Old Oct 12, 2012 | 01:36 PM
kurtwz's Avatar
Originally Posted by Nizzle;
Ball joints maybe?
Well, I had the car looked at by a pro mechanic. He went at the suspension with a prybar and couldn't find anything loose. We'd find a loose/worn tie rod end when looking that closely, right? Any other tests you can suggest?
Old Oct 12, 2012 | 06:11 PM
93RX7LSX's Avatar
For tie rod ends, with the vehicle turned off you have to turn the wheel from left to right very quickly. If you hear a clicking noise your tie rod ends are bad. Upper ball joints are inexpensive on these cars if yours are bad you will hear a clicking during suspension travel.
Put the vehicle on an oil change rack with weight on the wheels. Then try pulling down on the vehicle from the bottom of the car to hear any noise coming from the suspension components.
Old Oct 13, 2012 | 02:13 AM
AaronZ'sE63's Avatar
2007 E63 AMG
I know of this clunking noise you speak. More noticeable going at slow speeds on sloped pavement and especially on turns? I was experiencing it earlier this year and it was driving me crazy. I had front suspension ball joints and tie rods checked and re-checked. Its your sway bar bushings, which apparently can get mashed pretty good if you run on the tight suspension mode frequently or have low profile tires. Took a couple of trips by me to the stealer to figure it out. $1500 job due to sway bar bushings apparently not being able to be replaced without replacing the entire sway bar which is a lot of labor.
Old Oct 13, 2012 | 02:21 AM
2007 E63 AMG
oh, and if that's not it, take a look at the subframe bolts to be sure that there is no play or movement there. I had that issue in the rear that started as a light metallic clicking sound and eventually turned into a pretty loud rattle in the cabin of the car when going over any kind of uneven pavement. The bolts are apparently known to crack or become unfastened. You'll want to get that addressed quickly as damage to the subframe is an expensive repair.
Old Oct 14, 2012 | 09:38 PM
kurtwz's Avatar
Oh man...i did the car turned off and on its wheels and turn steering wheel back and forth test. Big clunking noises! I then drove car, tho, and still heard the noise from abruptly and sharply turning wheel back and forth, but it was much quieter than with car off. Don't know if it was quieter in absolute terms because power steering was helping or just relative terms becuase there was lots more noise when driving. Does the test producing the sound mean that i would hear the noise at times when i'm driving and not TRYING to produce the noise? That is, if i'm not yanking on the wheel side-to-side, will it still make noise like in going over bumps?
Also, no oil change rack available, but i did drop the weight on jack stands positioned under the lower control arms as far out to the sides of the car as i could. that is pretty close to weight being on the tires, i guess. Tried all i could to get sound to show itself, but only sound i heard (besides the steering wheel test) was in jiggling the wheels around. That's from wheel bearings being worn.
Thanks for tips. I tried raising suspension to #1 setting (no lowering lights on) and i still heard sound. May have been a little less bad, tho, with other setting. Swaybar bushings looked pretty good to me. Pulled and used pry bar on everything i could find and i couldn't reproduce sound.
Where are subframe bolts?
Old Oct 15, 2012 | 10:55 AM
speedpeddler's Avatar
2014 E63, Cobra replica, 68 Camaro, 66 Chevy II SS, Z4 BMW, Honda Element, Birel 125cc Shifter Kart.
Ditto on the sway bar bushings. Had the same noise and the same procedure to fix it. Try disconnecting the sway bar ends and driving the car to see if the noise goes away. Easy way to find out. But, why do we have to purchase the entire sway bar assembly instead of just replacing bushings? Seems stupid to me.
Old Oct 15, 2012 | 11:36 AM
2007 SL55 AMG
it may indicate that the shocks are making the noise.
yes, you have to replace the entire sway bar from what I remember.
Old Oct 15, 2012 | 09:12 PM
kurtwz's Avatar
[QUOTE=desired_speeds;5394804]it may indicate that the shocks are making the noise.
Car makes same awful noise in highest position (no lights on).
Old Oct 15, 2012 | 09:21 PM
kurtwz's Avatar
Ok here's the update...shared info from this thread with the mechanic who did the "diagnosis". As you can tell from my use of "quotation marks", it may not have been much of a "diagnosis" :-( I shared with him that I get a sound when the car is off and I move the steering wheel aggressively. He said that could be part of the problem! That'll teach ME to think for myself! Arrrgh! Anyway, now i need to research what specifically is the bad linkage.
But wouldn't i just see the bad tie rod end? They're out there where I can see them easily. Also, for upper ball joint it's not a clicking. It's definitely a clunk...pretty loud. Would you say it could still be the ball joint?
In any case, gents, the bearings are on the way. We'll see if it helps. I'm now only about 45% confident it will. Worth a shot, tho.
Old Oct 15, 2012 | 10:02 PM
terrymary512's Avatar
bmw
Anyone else seen this
Old Oct 15, 2012 | 10:45 PM
03'55AMG's Avatar
AMG
Dead pics there. ^^.
Old Nov 13, 2012 | 03:18 PM
F17RAK's Avatar
E55K AMG
sorry for bringing up an older thread, i am a fellow e55 owner from over the pond. I am also experiencing this clunking noise on rough surface roads. As desired speeds mentioned, my noise does go away after the car is raised.
Am i also looking at sway bar problem?
Old Nov 13, 2012 | 03:55 PM
2007 SL55 AMG
Disconnect your sway bar end links and drive around again with the car in lowered position then in raised position. If it still does it in one height and not the other, check the upper ball joint for play. Does the sound come from one side or both sides? Its usually hard to tell which side its coming from. Very rarely does it happen, but it can be the shock that is making the noise and the only solution would be to replace it.
Old Nov 13, 2012 | 07:00 PM
F17RAK's Avatar
E55K AMG
You cant really tell what side its from, i hear it from all over. But my mate sits in & says its from the front passenger ( driver side for us).
So its either sway bar bushes, upper ball joint or shock?
Is it easy enough to disconnect the sway bar?
Old Apr 1, 2015 | 09:57 PM
Djguilty's Avatar
04 E55 Amg 130k
I know this is an old tread, but any chance it's the strut mounts making the noise?
I have the same issue....
Old Apr 2, 2015 | 08:42 AM
kurtwz's Avatar
I never solved the issue,, but did replace the wheel bearings and that was not the problem. Never tried the strut mounts. Best of luck to you!!
Old Apr 2, 2015 | 09:17 AM
Hulk's Avatar
A Merc
Control arms and lower ball joints.
Old Apr 2, 2015 | 09:34 AM
E55Freak's Avatar
2005 E55 silver
mine was also making a weird noise, more like a squeak, when going over bumps at a slow pace. my mechanic looked at it and figured out it was a bad ball joint and spring link bushing...replaced those and an alignment and this car has never driven/handled better.
Old Apr 2, 2015 | 10:09 AM
BagMan's Avatar
E55, E320 CDI , CLA250, Jag XJ Supersport
The OP mentioned he had Arnott struts. Any chance the noise is coming from the Arnott strut?
I'm experiencing intermittent clunking when making U-turns. The noise started shortly after I installed Arnotts up front.
Dealer looked at it, but couldn't replicate the problem.
Old Apr 7, 2015 | 01:48 PM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
does the upper strut mount have a bearing or gap where the nut contacts the strut shaft? with other brand cars i've dealt with we've had to add washers to take up some slack, then use an airgun to gun the nut down so it wouldn't clunk.
generally the case with aftermarket struts.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
