DIY Wheel Bearing Replacement Thread?
Good luck!
Holy crap that's easy! Thanks!
edit: on a side note id shake the front end down first with a friend see if you can replicate the sound. a clunk is more likely to be a ball joint as a opposed to a bearing. bearings will give you a growling/grinding noise. progressivly getting lowder as they get worse, to the point it sound like a jet is taking off in your car. just my .02
Made the call that I'm guessing it's the bearings. I tried tightening the nut that locks it in position and that didn't take the play out of it. To test bearings for sound I lifted front of car up a few inches and rammed my knees into the side of the tire. It produced a sound similar to the one i'm hearing (albeit much quieter, of course).
I ordered Beck 051-4216, which includes inner and outer bearings and races + seal. $72 delivered from AutoPartsNetwork.com.
edit: on a side note id shake the front end down first with a friend see if you can replicate the sound. a clunk is more likely to be a ball joint as a opposed to a bearing. bearings will give you a growling/grinding noise. progressivly getting lowder as they get worse, to the point it sound like a jet is taking off in your car. just my .02 .
I fully accept I could've made the wrong determination here and i know what you're saying about the howl/grinding noise. i Can't deny the fact, tho, that the bearings are way looser than they should be and they make a clunk sound similar to the one i hear when driving. Hoping I made the right call--for once!
I see now that the company that makes the supercharger pulley bearing is the same company that makes these bearings. Here are the numbers:
Outer: NTN ETA-LM12710-2 JAPAN HN
Inner: NTN ET 32008XPX | OV6 JAPAN HL
