Header coming loose?!
Old Oct 14, 2012 | 03:33 PM
Jakez's Avatar
'03 E55 AMG - '06 300C SRT8 - '93 240SX Coupe w/1JZ-GTE
I noticed an exhaust-leak/muffled type of low tone coming from the engine area this morning when I started the car. So I popped the hood and looked around and noticed this.. also sounds like the noise is coming from this area..
I don't know what this is SUPPOSED TO look like but it doesn't look right to me. You can clearly see the bolt thread and spacing between the two pieces. Is there a bolt missing?!
Old Oct 14, 2012 | 04:22 PM
vioilio's Avatar
2003 E55 AMG
This is spring loaded bolt so gap/ spacing is normal. If there is an exhaust leak you will see some burnt black marks .
Old Oct 14, 2012 | 04:24 PM
GT-ER's Avatar
2005 E55 AMG
It's a ball and socket type flange. It looks fine to me.
Old Oct 14, 2012 | 06:17 PM
E55Greasemonkey's Avatar
This place is a joke.
Looks normal. Smell around the engine compartment at idle and see if you detect any raw exhaust smells
Old Oct 14, 2012 | 08:38 PM
layzie12g's Avatar
2008 Mercedes Benz E63
Looks similar to my CL55.
Old Oct 14, 2012 | 08:55 PM
e55amgrocket's Avatar
Dirt Scooters
It might be cracked where the flange is.
Old Oct 14, 2012 | 10:32 PM
hollandca12's Avatar
I've had copper bolts on my renntech headers loosen up twice over past 2 years. Its a real PITA and I'm not sure on why it keeps occurring. Each time I've notice the leak is on cold morning start ups in the garage, As well I occasional get a low resonance hum in the cabin at low speeds. I finally ordered new bolts to replace the old ones to see of that will address the issue. No issues with the connection between the headers and primary cats as you illustrate.
Hopefully someone can get some insight into fixes....
Old Oct 14, 2012 | 10:46 PM
Jakez's Avatar
Hm interesting.. well I know I didn't have that noise before and I did a lot of racing last night before I parked her and also a good 100mph+ blast for a straight 1/2 hour on the way home. Me and a friend are thinking that the fast and long drive home might have heated things up too much and burnt a gasket out? Not sure. It's just scarey hearing it I don't want my engine to blow or something lol. And there's no error codes on the screen or anything so what the hell.. she still pulls fine and everything though. And after getting up to 40mph or so the noise doesn't seem to be there or get any louder.
Old Oct 14, 2012 | 10:55 PM
Shifter's Avatar
E55, SL63, ML550
I've seen E55 with shot motor mounts cause the stock manifolds to break. Are you're mounts good? Do you have stock manifolds?
Old Oct 16, 2012 | 11:53 AM
Jakez's Avatar
Also attached a pic of my rear main seal, how BAD does that leak look? Dealership told me I had the leak but it "wasn't serious".
Old Oct 23, 2012 | 04:51 PM
Jakez's Avatar
Ok pretty sure I've found my leak. I can feel the air coming out. Look at this
Old Oct 23, 2012 | 05:03 PM
Dirt Scooters
same place my stock set broke. Time to upgrade
Old Oct 23, 2012 | 05:36 PM
Jakez's Avatar
So I guess I am getting headers sooner than I imagined.. lol.
Is there any immediate danger with a leak like this? Such as running lean or something.. I really like to "beat" on my cars so to speak but worried running through gears with this leak might cause some other problems..
Old Oct 23, 2012 | 05:57 PM
AMG E Power's Avatar
E55 amg
Got my stock ones if u need them
Old Oct 23, 2012 | 06:01 PM
SilverStrk's Avatar
05 E55, 07 ML500
MBH Headers and call it a day, you won't regret..
Old Oct 23, 2012 | 06:50 PM
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
Kleemann headers are a great affordable option and make great power
Old Oct 24, 2012 | 02:20 AM
Jakez's Avatar
Well I'm going to have my local shop put some welds on it to hopefully cure it for now. I also have a fluttering or click clacking sound that appears when I give it some light throttle and I thought it was some interal noise, hoping that sound is just the fluttering air coming out of this leak. I want to go Eurocharged stage 2 but after doing a bunch of headers research tonight I take it the Eurocharged headers have some fitment problems and the MBH ones are the way to go..
