Evosport | New evo2 Performance Brake Rotors
Old Oct 17, 2012 | 12:44 PM
sales @ evosport's Avatar
Mercedes-Benz AMG
The New evo2 Rotors Offer Significant Improvements And Innovations
The Evosport performance brake rotors are designed as a direct replacement for the OE 1 or 2-piece brakes (no modifications are necessary), and work with the factory AMG brake calipers. They offer a significant improvement in cooling and brake performance over factory brake rotors- now over 60% more air for improved cooling and reduced brake fade on street or track. In addition, not only will the upgraded "floating" rotor design help mitigate brake fade, but they are lighter than stock and reduce unsprung weight on the front or rear axle. This means better acceleration, braking and cornering. It's easy to see why the Evosport brake rotors are the best-selling brake upgrade on the market for your AMG vehicle!
:: What's New In evo2
Our new evo2 rotor design offers significant improvements and innovations over the evo1 (1st generation) rotor to increase the performance of your vehicle while improving the life of your brake components.
:: Redesigned Hats
The hats have been completely redesigned to be lighter and perform better. Engineered directional vents on each hat dramatically optimizes cooling and further improves airflow. Further, drive pin washers made of strong Inconel (used in military, aircraft engines and racing applications) are practically impervious to oxidation or corrosion. Curved design on the drive pin washer add additional tension to the assembly thus reducing rattle and offering a quieter ride. The elongated drive pin holes allow independent expansion of the rotor and hat without coning. All front rotors are now made of lightweight aircraft-grade 7075 aluminum to offer additional strength and resilience.
:: More vanes. More cooling
The new discs now feature twice the number of vanes that are uniquely designed to optimize airflow inside the rotor. This improved design further minimizes turbulence and results in up to 80% better airflow than the OE rotor. This translates to even less brake fade and an increase in overall braking performance. Additional material has also been added to the outer rings to offer increased rotor life and resiliency under track and hard braking conditions. More so, a special alloy mix has been used during casting to specifically increase hardness and tensile strength values, producing a rotor that has added crack resistance. All discs are zinc plated to prevent corrosion.
Rotors are 100% made in the USA.
Why these are a must-have:
• Direct bolt-on requires no modification (works with OE calipers)
• Reduced unsprung weight over stock
• Aircraft-grade aluminum hats; black anodized
• Directional vents on hats for additional cooling
• Better value and lower cost of ownership over OE
• Replaceable outer ring and hardware (unlike OE)
• Proper venting for left and right application (unlike OE)
• More efficient heat dissipation and less brake fade
• Improved acceleration, braking and cornering with less weight
• Rotors are zinc plated to prevent corrosion and mitigate oxidation
Bolt-on applications for:
• C63 (W204) Coupe/Sed/Wag/AMG Black Series Coupe
• C63 (W204) AMG Black Series Coupe
• CLK63 (W209); CLK63 (W209) Black Series
• CLK63 (W209)
• SLK55 (R171) w/ P30 PP; SLK55 (R172)
• E55 (W211) Sed/Wag; E63 (W211/W212) Sed/Wag; E500 (W212)
• E550 (W207) Coupe
• CLS55 (W219); CLS63 (W219)W218)
• CLS63 (W218)
• CLS63 (W219) w/ P30 PP (not for Ceramic Brakes)
• S55 Komp (W220); S500/550/600 (W221); S63/S65 (W221)
• CL55 Komp (W215); CL500/550/600 (W216); CL63/65 (W221)
• SL55 (R230); SL65 (R230 not Black Series); SL600 (R230)
• SL63 (R230); SL63 (R230) w/ P30 PP
• SLS (C197) (not for cars w/ Ceramic Brakes)
Ask About Our 390mm Upgrade for vehicles w/ 360mm rotors
Most applications available for immediate delivery. Call, EMAIL us, or CLICK to order or for more information.
Old Oct 17, 2012 | 01:43 PM
vioilio's Avatar
2003 E55 AMG
I have the drilled/slotted ver.1 rotors on my car and can say that I'm really impressed with the build quality.
Old Oct 17, 2012 | 11:53 PM
jcjmw's Avatar
2005 E55 Wagon
What is the price for front and back rotors on W211 e55? And, weight of these rotors?
Old Oct 18, 2012 | 08:56 AM
cij911's Avatar
one car at a time
Are these made by StopTech or RacingBrake ? Who makes the actual rotors ?
Old Oct 18, 2012 | 04:17 PM
pnoyworx's Avatar
10 E63, Sold -07 E63
going to need a set soon. Whats the info on upgrading to 390mm? Also pad recommendation for your rotors? Thanks.
Old Oct 18, 2012 | 05:00 PM
PACougar's Avatar
1000Hp Diesel Trucks, 2019 E63s
They're made by Stoptech, the pictures are even pulled from Stoptech's website.
Old Oct 18, 2012 | 05:58 PM
Mercedes-Benz AMG
Pricing for N. American market is $2,450/set for the 360/330mm E55 setup. For outside N. America please contact your nearest Evosport dealer (a list of dealers can be found on our website).
Weights are 28.0lb front and 14.0lb rear.
The 390mm upgrade for cars with 360mm will include an adapter kit to allow for the 390 to bolt-on to the OE caliper. Pad recommendations will vary depending on application and use. The OE pad will work fine, as will pads from Akebono and Pagid, for example. Please contact us for more information.
Old Oct 18, 2012 | 06:07 PM
pnoyworx's Avatar
[/QUOTE]
The 390mm upgrade for cars with 360mm will include an adapter kit to allow for the 390 to bolt-on to the OE caliper. Pad recommendations will vary depending on application and use. The OE pad will work fine, as will pads from Akebono and Pagid, for example. Please contact us for more information.[/QUOTE]
will I still be able to use my OE 18's. Also please pm price with 390mm kit. Thank you.
Old Oct 18, 2012 | 06:15 PM
Mercedes-Benz AMG
Depends on the 18" wheel. We recommend 19" wheels for correct fitment.
I will PM you pricing now.
Old May 29, 2014 | 10:13 PM
BlackieAMG's Avatar
2008 cl63 amg/2015 gla250 4matic
i need front rotors for 2008 cl63 amg w216 any available ?
Old May 29, 2014 | 10:30 PM
Duc1098E500's Avatar
Honda Metropolitan
Lol, you won't get it from these guys. They are scums and are out of business.
Old May 30, 2014 | 04:28 AM
AMGAffalterbach's Avatar
2014 BMW M235i
I know they went out of business but what was the story around them being scums, I've heard it before but not sure why
Old May 30, 2014 | 04:41 AM
2014 BMW M235i
Never mind, did some research and it's quite obvious they are really scum of the earth and their idiot lawyer is an unprofessional moron who takes pride in threatening elderly people. Wow.
Old May 30, 2014 | 08:38 AM
moosejaw's Avatar
none
Girodisc made their rotors look em up
out of bellingham wash
Old May 30, 2014 | 11:56 AM
Denroll's Avatar
'06 E55
Still waiting for those top mount intercoolers that I pre-paid for with cash up front.
Old May 30, 2014 | 02:44 PM
Honda Metropolitan
I'm still waiting for e63 floating front rotors and all around pads. Fully paid! ****ing scums!
Old Jul 17, 2016 | 05:54 PM
yarf's Avatar
CLK63BS
Old thread, but wanted to thank you for that pointer
