lets get a wolf pack of 55s to hit n.e.d this sat
Old 10-24-2012, 04:32 PM
skratch77's Avatar
2005 E55
I think its the last day there open and will be my first time there this season.
I'll be there and hope to see some amgs up there.
Greg
Andrew
Dima
Let's do this!
Old 10-24-2012, 11:07 PM
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
Just got home from NED.. Ran a 12.03 @ 115 with a 1.80 60'.. This is without the s/c pulley on, so tune only.
Weather is not looking to go for saturday, so I think im done for the season.. Did you figure out the clk wheels yet?
Old 10-24-2012, 11:09 PM
skratch77's Avatar
2005 E55
ill have them on the car tom,left them at my friends shop.You went up there and ran without the clks?
Old 10-24-2012, 11:16 PM
AKnight55's Avatar
ya street tires.. Got to get them real hot to hook.. Who drilled them for you?
Might be down to watch saturday if you go
Old 10-24-2012, 11:21 PM
skratch77's Avatar
2005 E55
it takes 5 seconds to drill the holes,bought a 5/8th bit and drilled each each hole.legot took like 5 seconds per hole.
wanna sell that pulley
Old 10-24-2012, 11:31 PM
AKnight55's Avatar
Ha how much? Im putting my car away at the end of the month anyways, so would just be sitting in my closet lol
Old 10-25-2012, 09:52 AM
PLATINUM SPONSOR
Exotic-metal55's Avatar
2003 CL55
Post some vids!
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old 10-25-2012, 10:41 AM
Former Vendor of MBWorld
BI-Performance's Avatar
E55 AMG on Ethanol-Meth; 600rwhp BMW M5
So close to 11's with tune only on streets, good run brotha
Old 10-25-2012, 10:44 AM
AKnight55's Avatar
Thanks Craig.. I really think I need to do the split cooling.. My AITs at the beginning of my run were around 100 and at the end got up to around 150.. Ambient was around 50..
Old 10-25-2012, 10:45 AM
GregMB's Avatar
As much as I'd like to spend the day with you guys to lay down some consistent 14-second passes, I will be working on some "not so glamorous" home improvement projects this weekend. Winter is coming....
-G
Old 10-25-2012, 11:08 AM
skratch77's Avatar
2005 E55
-G
14s lol I ran a 12.5 bone stock to the tires
PS its the last day that there open also!
Old 10-25-2012, 11:16 AM
GregMB's Avatar
I have no illusions about my abilities on the 1/4 mile.
Having never made a single pass, I'm sure I would be nervous and blow the launch most of the time....
-G
Old 10-25-2012, 12:45 PM
AKnight55's Avatar
-G
It's easy, we need to get you out there. Get the tires nice and hot and you'll have no problems making a good pass.
Old 10-25-2012, 01:00 PM
E55Dimon's Avatar
E63S
Damn last day. I'm out for tire reasons too. Not looking to get rubber all over the cv3's.
Old 10-25-2012, 02:04 PM
skratch77's Avatar
2005 E55
I'm at townfair getting new fronts and alignment.just dropped 625 for 2 front super sports and just installed the special bolts from mb to help camber.
PS for people that have a whine with there car I bought mb power steering fluid and added a little and my car is silent now(it was a little low)so I think the whine is the power steering pump.
Old 10-25-2012, 02:08 PM
AKnight55's Avatar
You getting the drag set up on?
Old 10-25-2012, 02:15 PM
skratch77's Avatar
2005 E55
Not yet there at my friends shop.I needed new fronts because the insides were showing threads.you should inspect yours too since you're lowered.
Old 10-26-2012, 09:29 AM
Jimshorts's Avatar
'05 SL65, '13 FX4 Eco
DUDE! I told you to run on street tires... I dont want to hear this "I wont hook" bull**** anymore lol. A 1.80 on streets is insane at NED! Best I ever managed was a 1.89 there and was able to crack into the 11s.
Ill try to get the X5M out there on saturday... you better bring the beast if its not raining. If I can get some decent launches we should have some good runs. I just have to pray to catch a perfect tree against you. I might have to run the race gas tune to make things interesting!!!!
Old 10-26-2012, 09:32 AM
AKnight55's Avatar
Im getting the pulley put on saturday morning.. If EC is able to get me a re-tune after that, then ill head there for sure and make a couple passes.. Would definately be in the 11s then.. But If I cant get a re-tune, then I cant run it.
Old 10-26-2012, 09:42 AM
Jimshorts's Avatar
Oh for sure. I could see you cracking off a 11.8x on streets with that S/C pulley. With drags 11.6-11.7. I wonder what the trap will be? 119+? Thats hauling man! I wish I could have figured out my beast before I sold it. Would have loved to see a 120 trap. Ive been looking at some SL55s for a summer car. Cant wait to get back into an AMG.
Old 10-26-2012, 09:43 AM
skratch77's Avatar
2005 E55
I might be out for tom.I had a long night last night.
I had 4 big guys in the car and the front shock popped and slammed my car to the ground.I jacked it up and the link came off the sensor so I don't know if its from an airnatic failure that it cane off or from the guys that changed my tires and maybe bumped it and it popped off.
Didn't ruin the night though I babied it home and took out the Honda and went to tens lol
Old 10-26-2012, 09:52 AM
skratch77's Avatar
2005 E55
Old 10-26-2012, 11:11 PM
skratch77's Avatar
2005 E55
I will be up there tom around noon
worked on the car most of the day but need to install tb and remove front grill and filters in the morning.
Still cant put the power down even in second gear with the r888s tho but the car feels faster than ever,3rd rear litterally lifts the front of the car up lol
Old 10-26-2012, 11:21 PM
AKnight55's Avatar
I might stop by in the afternoon.. Ill have my pulley on, but no re-tune
Old 10-27-2012, 12:08 AM
skratch77's Avatar
2005 E55
cool beans
I ended up using a 15mm spacer and the longer lugs I got with my f14s to run the r888s the 20mm adapters pushed the wheels to far out.
Quick Reply: lets get a wolf pack of 55s to hit n.e.d this sat
