Is there a good spot to pull 12v power in glove box?
e46 m3, w211 e55
I want to wire in a USB connector for power there. Any suggestions on where to pull power in this area?
If constant would I be ok if I kept a bluetooth dongle on or would it drain battery?
1 Post
2004 E55K AMG Wagon
I wired from the back of the lighter into the coin tray next to the glovebox, I have a 3G Mifi there which allows 5 devices to connect. The supply is switched off when the car is removed so it will run off its internal battery but nromally just goes into standby. I can also use the USB connector to power other devices if needed.
