Brand New Ferrari 458 Spider
It sounds like you need to keep one of those sleeping blindfolds in the glove box and blast lullabies for your wife to mask out any exhaust note. I know the feeling, maybe not to the same extent, but the opportunity never comes up when I'm alone. Occasionally I deal with a similar situation which ends with my wife usually trying to brace herself with her feet on the dash. You car must be pretty mean I'm glad you took advantage of the opportunity most wish to have.
458 is a sweet car. Just think if you were in a E55 Wagon, he really would have been shaking his head !!!
Sounds like the roads over there are great for speed !!
The last victim of my "taxi" was a Porsche Panamera S that gave up at 170mph
The 45 degree OAT is really helpful. I noted my IAT was at about 59 degrees and never went above 140 degrees during the run. The larger H/E and the other cooling mods are all helpful. Had this been a 95 degree day, the outcome may not have been the same. On the other hand, I was probably more than 300 lbs heaver than normal (no it’s not my 5’10” terrorized wife) so, who knows? What I do know is that the E63 BT has the potential of going far beyond the already amazing achievements of the E55. The E55 is an amazing cruiser/marauder, but it’s days are numbered. My only real concern with the BT is the mating of the 7 speed G-Tronic. Can it absorb the torque increases that are already being placed on it? As I understand, the SL65 continues to utilize a beefed-up 722 to handle the torque. Only time will tell and only time will bring the cost of a pre-owned BT down to a reasonable level.
MB W211 drag coefficient is .26
The Mercedes is WAY more slippery. At those speeds the Ferrari is generating way more down force but that down force robs HP and effectively makes the car "heavier".
Nice story.
Our E55 has a custom rail similar to Bruce's, but utilizing 6 port SLR injectors. Ported 80mm TB, Vadim shorty/HEM's, ported cats, 168 ASP pulley, phenolic spacers, K&N's, insulated induction system, heat exchanger, pump, secondary cat & resonator delete, modified X-pipe/expansion chamber, ECU, light weight rotors, CF drive shaft, LSD, K-MAC, bushings, Toe-Links , oil catch can. I will install MBH's LT's next year because they are simply the best and will not scrape on my driveway entrance. The Vadim shorty's/HEM are perhaps the last ones made and were of excellent quality and have held up perfectly. They actually incorporate a really good design which produced a significant improvement. Mike's LT's will also produce a significant improvement over and above the shorty's and with complete peace-of-mind. And that will be it until an E63TT comes into our life.
This E55 is driven as an elegant stealth cruiser punctuated by thrilling moments of unadulterated fun.
