has anyone done a TCU swap DIY?
Old Nov 28, 2012 | 10:27 AM
Toadster's Avatar
2005 E55 AMG
can't seem to find one...
Old Nov 28, 2012 | 10:29 AM
djrabbi's Avatar
EQS AMG, E53 AMG, GLE63s
Just pull back the passenger carpet and unbolt the steel liner. TCU is right next to the airmatic.
Old Nov 28, 2012 | 10:40 AM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
There are several black boxes under the passenger carpet plate, so make sure you send the TCU out to be tuned and not your airmatic module.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Nov 28, 2012 | 10:44 AM
moosejaw's Avatar
none
Dont rip the carpet like i did.......oops
Old Nov 28, 2012 | 10:45 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
TCU will say EGS52 on it
Old Nov 28, 2012 | 11:05 AM
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
http://www.eurocharged.com/index.php/documents
same as 32
Old Nov 28, 2012 | 12:35 PM
Toadster's Avatar
2005 E55 AMG
Originally Posted by loungn14
cool thanks - I figure with this black friday deal going, on - there will be lots of "where is it?" questions
Old Nov 28, 2012 | 01:10 PM
SavMan's Avatar
2004 E55K AMG Wagon
This is a close up of mine, I emailed to EC before removing and they confirmed i had the right box
has anyone done a TCU swap DIY?-cid_54a3147e541442708a0c1a7bc8485658-upstairspc.jpg
Old Nov 28, 2012 | 05:27 PM
urbamworm's Avatar
05 White Pano E55, Cadillac CTS-V
It is so easy a caveman could do it.
Old Sep 12, 2018 | 07:05 AM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
Is the TCU for the E63 located in the same place as the E55?
Old Sep 12, 2018 | 09:45 AM
whipplem104's Avatar
1990 300ce supercharged and intercooled
No its inside your transmission on the valve body. It is what you would think of as the conductor plate on a 722.6.
Old Sep 12, 2018 | 01:11 PM
gjunon's Avatar
04 E55 AMG
When you're looking at the 3 boxes it is the bottom driver's side box. It will have 2 connecting wires.
