I want gears. Pray for me lol
I located another place that I have emailed that does work on GM, Ford, Dodge and has "Imports" listed on their site, and waiting to hear back from them now. Came across them on LS1tech site with many having good words for them. My plan is to go with the 3.23 ratio if this place will do it, if they say no then I am not sure where to go next.
I would do it myself since I have always done all my own work, but I just don't have knowledge in rear ends and don't want to mess up anything like getting backlash right or whatever. I haven't looked in to it so hell it could be extremely easy, I just right now would rather pay someone to do it and stay clean
For people that may be in the know, how long does something like this take? And if anyone in the Jacksonville, Florida area knows of a place I should check with let me know!
Oh, PM sent too
I think the 3.06 would be the ideal set for these cars. Improves acceleration without shortening the highway gears too much. Be sure to let us know what you think after driving for a while.
I went with 3.06's and a 28" slick because of all the TQ my cars make from E85, if I went any higher, it would be useless. I will go through the traps in the mid 6700rpm range with this setup. I was going to a 28" tire regardless, just a matter of top of 3rd or top of 4th.
I feared my car would not 60ft with the 3.73 gear out the hole, just like it cant right now. It turns the hoosiers on the clk rims.
I opted to stay in 3rd for now, but for me, and everyone is different, I could careless about highway or streetability of the gear. I am not into top speed runs, if you want to run on the street, digs or nothing at all for me.
David- I would take into consideration what your plan is for the car before chosing a gear, but since yours is mainly street driven, I think a 3.23 or 3.55 would be BAWS in your sled. It just becomes tricky when chosing a gear for the track as you have to take into consideration alot of other factors.
I have also though about going down in pulley size since so often I am down on a lot of power from it always being hot and humid in Florida and the 180 kills me. I don't know why because it doesn't seem like some others suffer as bad but mine absolutely hates it. I have a car that will trap 111mph to 120mph dependent on if it is 60 or 85 out, it is just stupid. And I have a 180 pulley, Kleeman headers, no cats, Eurocharged heat exchanger, Johnson pump, 80mm throttle body, Eurocharged ecu and tcu tune, 550cc injectors, Paramount Performance valve body and a 1.5 gallon underhood separated coolant tank. You would think the car would be a little more consistently fast.
No but they are pretty far from me, that is about 5 hours away, also I am not sure if they would do something like this, all I know them for is working on Evos and stuff like that. I am trying to find something within 30 minutes or so to make it easy and not some big production to get this done, especially since I am so limited on time. Jacksonville is the largest landmass city in the U.S., you would think I could find a place not to far away.
I am only home for 3 weeks this trip home and at least one of it and probably closer to 2 will be spent in the Florida Keys where there certainly aren't performance shops so I really only have a week. Sucks because I keep coming home for small time periods while I am working overseas so it is hard to get anything done. Then I get to play with it for a small period and then leave which is frustrating!
http://www.youtube.com/watch?v=GYFaL3_OcuY
