Pleased with Arnott
I'd recommend that while you have the strut out to replace your swaybar endlinks, or at least make sure the top bolt is TIGHT.
My fronts seems little loose but not leaking; 55k. Was thinking about replacing them.
Not having done it before, I'd say it took an hour to replace the first one. That includes getting the car on stands and everything loose. Once you have the lower bolt removed, as well as the 4 top nuts and wires/hose disconnected, you can work the lower part of the strut over the lower control arm. That way you won't have to mess with ball joints etc. Turn the wheel left or right to find the most room to work.
I actually think dealing with the harness in the fenderwell is the worst part of the job.
I can tell no difference in ride or performance to that of the OEM units.
Installation was pretty straight forward and not difficult. I did not have STAR and simply used a pry bar to compress the strut and move lower strut mounting tab to the mounting point.
Thanks, very helpful thread!
Alex
I notice some of you have a STAR? Exactly what is STAR? I know MB has their bizillion$$ startrek unit and I assume you aren't referring to that.
Is the STAR a stand alone computer for home use? Is it price reasonable? Thanks.
