Do the W220 S55 and W221 E55 have exactly the same wheels
Old Jan 15, 2013 | 07:20 PM
OZZYAMG's Avatar
03 W211 E55
Hi
I have found a set of genuine wheels off an S55 W220 shape Mercedes with part number: A2204013502
Does anybody know if these are the exact same wheel pattern and offset that I have on my standard 2003 AMG E55 Kompressor?
Regards,
OZZYAMG
Old Jan 15, 2013 | 08:12 PM
FASN8N's Avatar
CTSV/6sp Grocery Getter
The W211 E55 wheels have the following specs
A2114012602 18x8 ET30
A2114012702 18x9 ET39
The part number you gave is for the rear wheels 18x9" ET44
The wheels should sit further in by 9mm
http://www.1010tires.com/WheelOffsetCalculator.asp
Hope this helps
Old Jan 15, 2013 | 10:08 PM
OZZYAMG's Avatar
03 W211 E55
Hi
Thankyou for your reply.
Regards,
OZZYAMG
Old Nov 3, 2021 | 01:43 AM
Andres Morejon's Avatar
2005 E55 AMG
Was anyone able to make the swap? I'm thinking of buying s55 rims to replace my aftermarket ones on my w211 e55 and wonder if a simple set of spacers is all I will need.
Old Nov 3, 2021 | 02:53 PM
Sulaco's Avatar
1999 C43 AMG, 2005 E55 Wagon
I had 1 S55 wheel on the back of mine. It required longer lug bolts to fit. It stuck out a few MM over OEM.
I've since replaced all 4 with CLS55 OEM wheels.
Old Nov 4, 2021 | 11:31 AM
2005 E55 AMG
Thanks for the reply. So I guess it should be an ok swap with different lug bolts. Did you need any spacers or anything for the fronts?
Old Nov 4, 2021 | 08:29 PM
Sulaco's Avatar
I did not have S55 wheels on front, so I can't comment there, unfortunately. Sorry.
Old Nov 4, 2021 | 08:30 PM
E55Greasemonkey's Avatar
This place is a joke.
The S55 wheels have a more squared shape to the spokes, and look goofy on an E55.
Old Nov 4, 2021 | 10:01 PM
Sulaco's Avatar
Most S55 wheels were identical in appearance to w211 E55 wheels. They only differed in offset and fitment.
Attached is a pic of an S55 wheel on the rear of my E55.
Old Nov 4, 2021 | 10:50 PM
They're not identical. I can spot them every time. I got real good at it looking through Craigslist or Offerup for a used set of wheels, as most knuckleheads selling them don't know which model they came off of. Look at the top of the rear wheels where the 2 spokes meet the lip. Note the sharper angles vs. the front wheel at the same location. The spokes are also thicker on the S55.
The fitment on your wagon looks goofy...the front tires look beefier while the rear wheels sit in too far and the tires are squeezed.
Old Nov 4, 2021 | 11:06 PM
Sulaco's Avatar
oh, cool! Can you tell me what it is about this wheel that makes it obviously an S55 wheel? I just can't seem to spt a difference
Old Nov 4, 2021 | 11:40 PM
Simple, just compare it to this E55 wheel, look closely! It's so obvious!
Old Nov 4, 2021 | 11:47 PM
Sulaco's Avatar
I'm really struggling to see a difference. Can you help me out here? Maybe point to a specific spot or something?
Old Nov 5, 2021 | 12:43 PM
machild's Avatar
2006 CLS55 AMG, 2005 SLK 350 AMG
I see a difference where the spokes come into the rim.
Old Nov 5, 2021 | 01:15 PM
I'm not sure if you're messing with me, 🤔 but you posted a picture of an E55 rim asking me how I know it's an S55 rim....so, I posted a picture of an S55 rim telling you it's an E55 rim. 😉
Seriously though, the difference is in the spokes. The S55 are thicker and more squared than the E/CLS/SL55 rims.
