Sneak preview of current project
PLATINUM SPONSOR
Very nice set up ! When is the test day? Is the whipple valve , just basically a turbo blow off valve?
Did you consider making the spacers out of phenolic?
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
If the whipple valve he's using is the same as the one they use for the Fords and Hot Rod kits, its more like a throttle body blade with a rod hooked to the cam instead of a cable. Then a diaphragm can pull on it from wherever you want. They're easier to fit in tight spots than a BOV
can someone explain the advantages of having this done, its the second set i've seen lately... just some extra info about the setup would be great.. thanks
volume of the the original. I should see a lot less pressure drop from the SC discharge to the intercooler discharge. I'll also have a done for cooling capacity!
#32
Have you installed the bigger intercooler?
Does it work the way you thought?
Here in Germany a company called TTP had buildt M113ML with about 750hp (at crank) and the boss of the company told me they used the stock IC up to 750hp.
Their optinion is, that there is no need for an IC upgrade.
Upgrades for the IC-system are necessary, but no upgrade of the IC itself.
#35
05 White Pano E55, Cadillac CTS-V
There is quantitative data showing there is a problem with the stock intercooler via hundreds of data logs, both while logging on the dyno and on the street with larger heat exchangers up front, larger coolant tanks and higher flowing pumps. The boss of that company is an idiot lol. He may claim 750hp when the engine is cold, but then ask him how much hp it has after it does one run.
#36
Just wanting to know if this activity is worth on cost-benefit-ratio.
@PACougar: Do you have any data log before and after installation? Development of IATs?
#37
As soon as I get a tune to eliminate the bypass I'll let you know. For other reasons I have the heads off right now, should have it back up this weekend with the new IC. As David said above there is lot's of data dealing with how crappy the factory IC is. If you need real proof look to MB, they built a top mount system for the SLR and that car is nowhere near 750hp to the crank. If the stock IC has no problems going that high why would they have spent all that money building a unnecessary setup for a 626hp car?
#41
