Eurocharged Euro-Flash! Data Logging, OBDII Code Functions, and ECU Flashing!!
Old 06-11-2013, 10:52 PM
  #176
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
Tried to upload the new tune today and I am somehow stuck in recovery mode as well. I guess I have to send my ECU to EC now. I hope they can figure it out
Old 06-12-2013, 03:45 PM
  #177
Crissus's Avatar
C215 CL55 AMG, W124 500E, W210 E430, W124 300E
FYI, i read in another thread that EC can let your IC pump to run all the time with their tune. Excellent! :-)
Old 06-12-2013, 04:05 PM
  #178
AKnight55's Avatar
Yes this is true.
Old 01-20-2014, 09:36 AM
  #179
jcjmw's Avatar
2005 E55 Wagon
Originally Posted by sales@eurocharged.com
We are finishing up a few detailed areas of the software and once this is done I will let everyone know.
We are also testing a version of the software that will allow the end user to make a few changes to their own tune. We will provide a base tune and the user can change a few key maps to tailor the tune to their specific needs.
Ignition: + or - 3 degree maximum in a specified load range
Fueling: Specify a lambda value for part and full throttle fueling maps
RPM Limiter: Specify a RPM Limit for Manual Mode
Top Speed: Debating on adding this...the base tune takes care of it but you never know.
Map Sensor Voltage: Adjust the maximum value
This version of the software will not be free and will be available shortly after our initial release.
The hard part is determining what we should allow the user to do.... for obvious reasons.
Is this version - that allows the end user to make these above changes on out own - avaiable?
Old 01-20-2014, 12:41 PM
  #180
SPONSOR
sales@eurocharged.com's Avatar
C63S
no sir, sorry
Quick Reply: Eurocharged Euro-Flash! Data Logging, OBDII Code Functions, and ECU Flashing!!
