Finally got my ELM installed
Looking clean Manuyc!!
How flexible is programming the V2 ELM?
Is there a way to have the car drop all the way when you park and lock the car? Then, raise back up when you start the car and drive? (Similar to proper aftermarket air ride.)
You get a hardwired remote that allows you to lower or raise the vehicle in 5mm increments. I believe the max was 50mm.
So you could drop the car as low as you want with the remote before locking it and then raise it back up when you leave.
2016 Cls63s AMG
There is no programming per say the ELM V2.
Car looks great! Thinking of this ELM also. When you have the car lowered and lock it in position does the car still automatically lower more after 75 mph? What happens if you install this once your car has been star lowered already?
06 e55,81SC Targa,08 CLK63 BLK,91 E34 M5
I set it one just below the lowest setting in the front. And two below the lowest in the back.
It's all fully functionable modual. If you feel that it's to low or to high and want to set the ride height different again just unscrew the modual and dial the knobs to the right ride height you want it to sit at. I put the modual right under the passenger dashboard and behind the carpet it has long enough wires to pull it out and work with
E63s s213 2019 ,SOLD E63 Weistec, E55, C36
looks good!
I know of one member who had a problem with a loose connection actually in the remote, but he fixed that.
Remote works great , i think its the best ELM out there better than the v3 as it doesnt need a laptop!
OUCH. Last year a member was selling brand new v2's for $700, granted it was a GB.
Thats why I won't make an offer. . .
OP - Looks good, I'm star lowerd and I'm thinking of a v2 also so I have even more flexiblity.
