Diagnose Secondary Air Injection, EGR, and Post Cat 02 Sensors through SDS
Old Dec 9, 2015 | 08:11 PM
  #76
speedtrap52's Avatar
2005 C55
Originally Posted by MouTine
No update here uh?
Friend of mine and I were able to change post-O2-sensors (0182) and SAI (0178) into "AUS". But... EGR (0176) kept poping back to "EIN" no matter what we tryed. Any help on this?
And one other thing too... Vmax (0224)
there wasn't higher option than 250kph awaible. Why? Where I could switch 300kph?
Help please?
I have the same issue with egr, did you find any solution?
Old Dec 9, 2015 | 08:24 PM
  #77
JoeNobody's Avatar
Mercedes
Meh
Old Dec 9, 2015 | 08:44 PM
  #78
2005 C55
I did, it coded Sai and secondary O2, but egr won't stay coded.
Old Feb 10, 2016 | 04:19 AM
  #79
austingtir's Avatar
2004 E55 AMG, 2006 CLS63, 2004 ML55, 2014 E350 sport
Old thread: )
I have removed primary cats and secondary cats (im not in the USA).
I am going to recode the car to suit this i have star diag.
I am reading on here in my searches of people complaining about fuel smells when they deleted the primary cats?
Is this because of secondary air injection (cold start mixture richen?) or because of the factory tune?
I am building a set of headers and want to see how the car runs without any cats before I build these headers so I know weather I will need atleast one set of cats or not if the thing reaks of fuel which I doubt I can put up with.
I figure there must be a way around this while still removing all cats and secondary air injection, Maybe EGR to? Obviously id prefer not to tune it atm until I finish the headers I just want to run it as is to test it but im still interested in others experience with this??
Old Jul 21, 2016 | 02:11 PM
  #80
biker349's Avatar
cl600
great info. thanks
Old Jul 24, 2016 | 02:51 PM
  #81
BoostedAero's Avatar
2004 E55
1st mod LTH done this weekend...this is right on time
Thanks kindly sir, thinking I can stop dealing with my 2nd o2's CEL now.
I just want to clarify;I am a South Carolina resident and my vehicle is NOT a "state road going vehicle", I just have pipe and tips...yes it is loud
So,I turn these off and I will NOT get a CEL from my LTH upgrade bc I am turning them off in dev mode where the ECU doesnt look for the 2nd o2 reading... correct?
Originally Posted by PACougar
Disclaimer: First of all this is for diagnostic purpose only!!! Second in most country's it's quite illegal to modify these on a road going vehicle, in fact in California it's illegal even if the vehicle is for off road purposes only. You should only use this to locate a problem and fix it.
You'll need a Dev mode SDS unit that's unlocked.
1. Select your car
2. Go to Control Units
3. Go to Drive
4. Go to MESFI 2.8
5. Go to Development Data
6. Go to Control Unit Adaptations
7. Go to Control Unit Adaptations(Variant Coding)
8. Go to Implizite Kodierung ME281 AMG C6-Stand
For EGR scroll down to 0176 and change Diagnose ein to Diagnose aus
For Secondary Air Injection scroll down to 0178 and change Diagnose ein Diagnose aus
For Post Cat 02 sensors scroll down to 0182 and change Diagnose ein Diagnose aus
That will disable each of those in the computer.
Old Jul 24, 2016 | 02:53 PM
  #82
PACougar's Avatar
1000Hp Diesel Trucks, 2019 E63s
Yes, that's basically how it works. You'll end up with no CEL for your LTH.
Old Jul 24, 2016 | 02:54 PM
  #83
2004 E55
Ignore my previous post...
This dummy just read the thread and answered my own ? yippeee
Old Jul 24, 2016 | 02:59 PM
  #84
PACougar's Avatar
It's all good
Old Jul 24, 2016 | 03:02 PM
  #85
Hulk's Avatar
A Merc
Look who the cat dragged in lol
Old Jul 24, 2016 | 03:04 PM
  #86
PACougar's Avatar
I try, I try. I still get notifications, one of these days I'll get back on board.
Old Jul 24, 2016 | 03:10 PM
  #87
Hulk's Avatar
A Merc
Old Aug 4, 2016 | 06:01 PM
  #88
jmb614's Avatar
E55 AMG
Originally Posted by JoeNobody
Fix it!
Needed to unlock the ECU first.
While car is running:
UNLOCK ME 2,8 SFI
control unit groups
drive
ME 2,8 SFI
development data
actuations
complete index of actuations
steuergerät entriegeln -> confirm (In English: ECU unlock for programming))
then apply variant coding while engine is still running.
Solution was found here:
http://www.benzworld.org/forums/r230...l#post12226361
For me it was sitzung variantcodierung einshalten (FN_ProgrammierMode)
Old Jan 30, 2017 | 03:02 PM
  #89
GEEWAGOON's Avatar
2006 G55
Can anyone do this for me?
Hello,
I had to remove my secondary air pump on my G55 because when I replaced my headlights with projectors the pump didn't fit. I removed the pump and blocked off the lines, but I have a CEL now.
Is there anyway to have this done remotely by someone or is there someone local in Dallas area that can help?
Thanks,
Old Jan 30, 2017 | 03:07 PM
  #90
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
CDM Motorsports
Old Jan 30, 2017 | 03:43 PM
  #91
GEEWAGOON's Avatar
2006 G55
Thanks Shardul! This place looks great I'm going to call right now!
Old Jan 30, 2017 | 04:21 PM
  #92
shardul's Avatar
Mention my name / UPD
Old Mar 20, 2017 | 11:36 AM
  #93
GEEWAGOON's Avatar
2006 G55
Shardul, FYI nobody ever got back to me at CDM Motorsports. I called 3 times, 2 messages and 1 time a guy picked up and took my info, but no response.
Anyway still in need of some programming for this if anyone knows someone or a shop that can help. Otherwise I might just have a new bracket built for the pump and mount it somewhere inside the engine bay.
Old Apr 3, 2017 | 10:40 PM
  #94
IvanWNY's Avatar
2005 S55
I have been fighting this for the past month.
I turned off sec air and o2s but they would never set as ready. Even driving it hundreds of miles the monitors wont set. I am not sure whats going on.
From​​​​​ what I have read here, turning off o2s shows them as N/A and sec air as READY. Any help is appreciated. 2005 S55, headers, no cats. Thanks
Old Apr 3, 2017 | 11:07 PM
  #95
IvanWNY's Avatar
2005 S55
Originally Posted by KnoxE55amg
Man this is a whole new car. Can't believe how choppy it was driving. Wide bands would fluctuate between 14.6 and 15.2 cruising now steady at 14.2. Full throttle fluctuated also. Now at 12.2 steady. Much smoother drivability.
Got to turn off rear 02's, EGR, secondary air and do -10deg mod.
Thanks Shardul!!!!!!!!
Did you have issues with monitors setting?
Old Apr 30, 2017 | 10:19 PM
  #96
IvanWNY's Avatar
2005 S55
FYI THIS WORKED FOR ME.
Up until today STAR did not help me because it would not set the other monitors BUT i have found a loop hole that works.
After ECU reset and driving the car for over 200 miles...still nothing set
EVAP, AIR, O2S, HRT and CAT wont set.
I was bored and sick of it and happened to try the following. I did the following with the car in the garage.
1. With car off, I pulled the N relay for sec air, started car and shut off. Scanned it with code scanner I/M sec air READY but has pending sec air code. Plugged N relay back in.
2. Disconnected evap purge valve, started car and shut it off. Scanned it... Immediately it set O2S and CAT as READY with pending evap code. Plugged evap back in.
3. Disconnected passanger side primary O2, started the car and shut it off. It set EVAP as ready. Plugged it back in.
So there you have it, this set everything except for HTR as long as there are no issues with any components. Pending codes don't matter as long as they don't come back and trigger a CEL. I think unplugging the rear O2s, starting it and shutting it off, plugging it back in might set HTR to READY.
I'm off to inspection with 3 pending codes and no CEL and with 7 out of 8 as ready.
Old May 1, 2017 | 06:33 AM
  #97
biker349's Avatar
cl600
good info. thanks.
Old Jun 11, 2018 | 08:04 PM
  #98
BC928's Avatar
2006 E55, Various other German and ‘Murican
And did this work for you?
Old Aug 2, 2018 | 10:41 AM
  #99
nishboo's Avatar
W124, W126, W140, W220, W222, R129
Does anybody know the code numbers for W221 S550 / W216 CL550?
Also, can this be done with W212 E350 over Xentry?
Old Aug 4, 2018 | 01:34 AM
  #100
APowerX's Avatar
C32 ///AMG, C200 CDI
have succesfully disabled the secundary air injection pump on my C32 AMG. a small question though, if you disable the o2 sensors does that mean the engine runs in open loop all the time?
