CEL Code P0456
Old Apr 9, 2013 | 04:02 PM
Ronan Mc Cabe's Avatar
Gone but not Forgotten 2006 E55 Renntech
CEL Code P0456
I recently got a CEL, code was P0456, minor evap leak.
For future users, it turned out to be a bad purge valve.
Old Apr 10, 2013 | 10:43 AM
BoZo.E55's Avatar
E55
Do happen to the the part number you used to replace it? As well, where is it located within the car? Thanks!
Old Apr 10, 2013 | 11:25 AM
moosejaw's Avatar
none
i have that error now as we speak
It has to do with my fuel leak
Old Apr 10, 2013 | 11:55 AM
I spoke too soon the purge valve did not fix the issue, indy is working on car again today to try and figure out the issue. I had fuel sender and gas tank replace March 2012.
Will post resolution as soon as I know.
Old Apr 10, 2013 | 12:24 PM
GunMoto's Avatar
EG8 | E46 | W211
+1
P0456 is more commonly due to an evap leak caused by a cracked/leaking fuel sender.
Old Apr 10, 2013 | 01:25 PM
moosejaw's Avatar
none
Originally Posted by GunMoto
+1
correcto mundo
doesnt look good for MB
because of that cracked fuel sender, i had to buy a Daily Beater
Old Apr 10, 2013 | 02:18 PM
GunMoto's Avatar
EG8 | E46 | W211
correcto mundo
I had the P0456 fault code and after reading many members who replaced the purge valve, which did not resolve the fault, I attributed the evap leak due to the leaking driver's side fuel sender (which I knew I had).
I bit the bullet, replaced the driver's side sender, cleared the code, and it hasn't come back since.
Until next time it comes back...stupid fuel sender.
Old Apr 10, 2013 | 02:40 PM
Well my indy has just about given up on it, he can't find any leak (ran smoke tests with 2 different machines). Just booked it into the dealer for next Tuesday. It better not be the sending unit again.
Old Apr 10, 2013 | 04:11 PM
GunMoto's Avatar
EG8 | E46 | W211
Are your fuel senders leaking right now?
If not, the other potential cause is a leaky bulkhead (for evap connection) on the top of the fuel tank (between the two senders). I believe this would require replacing the fuel tank.
Old Apr 10, 2013 | 04:30 PM
Indy has confirmed senders are good. Driver side sender & fuel tank (was leaking where you describe at top of tank) were replaced 13 months ago.
Old Apr 10, 2013 | 04:38 PM
GunMoto's Avatar
EG8 | E46 | W211
Hopefully, it's just a loose connection or dry rotted rubber hose. Give us an update if the dealer diagnoses the issue.
moosejaw's Avatar
none
Hulk replaced his senders at about the same timeframe.
Old Apr 10, 2013 | 05:13 PM
Hulk's Avatar
A Merc
Nope less than a year, everything was replaced feb 2012 including tank and then in nov 2012 senders again but no tank this time
What great products by MB lol
Old Apr 10, 2013 | 05:17 PM
Crissus's Avatar
C215 CL55 AMG, W124 500E, W210 E430, W124 300E
OMG... Is the CL C215 also affected by this issue?
Fuel Senders, whats that anyway? I thought fuel is delivered by a pump on the co-drivers side underneath the fueltank...
Old Apr 10, 2013 | 05:19 PM
GregMB's Avatar
I got that same code for the first time over the weekend.
I'm still playing the "3/4 tank fillup" game with my leaking tank, so when I saw that CEL I just cleared it with my iPhone and havent seen it since.
Almost 100% certainty that it's fuel leak related.
-G
Old Apr 10, 2013 | 05:28 PM
Jeez guys don't say that, better not be senders and or fuel tank again. I'll update as soon as I know anything further (next week).
Old Jun 13, 2013 | 03:11 PM
AMG E Power's Avatar
E55 amg
Bump !!! did u ever figure out the problem ?
Old Jun 13, 2013 | 03:17 PM
Yes, new purge valve, cleared code and no issues for 2 months and 6k miles.
Old Jun 13, 2013 | 03:19 PM
E55 amg
price ?
thanks for quick reply
Old Jun 13, 2013 | 03:23 PM
price ?
$85 for part (I don't know the part number, not on my paperwork). I don't know labor (I had some other work done at the same time) but would suggest no more than one hour?
